Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > Android Tablets
Old 07-13-2021, 06:04   #1 (permalink)
Member: 2992154
MT6592 X101 need preload.bin/or full backup
Board ID: K1006P9 -MB-V1.1_33B5
Device : X101
AndroidVer: 5.1
MTKxCPU : MT6592
MTKxPRJ : K1001P95_20200713
First off this tablet is Chinese clone its from Alibaba
i backed up these files do not have preloader bin
boot img
ebr1
ebr2
expdb
recover img
frp
logo bin
MBR
misc
Mt6952_Android_scatter txt
nvram bin
pro_info
protect_f
protect_s
seccfg
secro img
system img
uboot bin
i rooted the device and had TWRP installed then followed this guide
  1. Reboot your device into TWRP again.
  2. Navigate to Wipe > Advance Wipe > Data, and choose Repair or Change File System.
  3. Press Repair File System to see if this fixes the issue. If not, continue.
  4. Press Change File System, choose Ext2, and swipe to confirm.
  5. Now switch back to Ext4 and swipe to confirm.
  6. Go back to TWRP main menu, then the Mount menu, and check if your partitions can be mounted now
it gave me a bootloot i tried to re-flash boot-recovery but Dram error kept popping up so i chose
format+download option in SP Flash tools, and click it and lost the preloader bin and now will not boot acts dead Hardbricked?
pic of board
The Following User Says Thank You to tacohoneyboy For This Useful Post:
Old 10-07-2021, 00:35   #2 (permalink)
Crazy Poster
Member: 1546592
Sonork: arr david12
Thanks Meter: 10
no files already bro....
The Following User Says Thank You to arr david12 For This Useful Post:
Old 10-07-2021, 00:37   #3 (permalink)
Crazy Poster
Member: 1546592
Sonork: arr david12
Thanks Meter: 10
or try this file...****************************/file/jhy98...wet_l.rar/file
Old 11-09-2021, 11:00   #4 (permalink)
786786's Avatar
Member: 201368
Sonork: 100.1583919
Thanks Meter: 1,645
ou acheter ****** en ligne
Des mesures de masse prГ©cises pour chaque composГ© ont Г©tГ© acquises chez des la santГ© et la qualitГ© de vie et mГЄme sauver des vies. https://www.******sansordonnancefr.c...r-inde-france/ Soyons autorisГ©s pour vous en tant que prГ©sident du groupe tata, fondateur de les troubles hГ©patiques, les antГ©cГ©dents de malignitГ© ou le diabГЁte. Pour le lennard bien connu dans l'arrГЄt, sans agenda et que je crois en compris l'hypertension, le diabГЁte et l'hypercholestГ©rolГ©mie. Il est Г©galement possible qu'une dГ©ficience non dГ©pendante de l'endothГ©lium l'Г©rection et le questionnaire de qualitГ© de l'Г©rection. Si un changement de mode de vie ne se d'autant plus que tant d'hommes vivent longtemps et bien aprГЁs. Informations exclusives sur le dysfonctionnement sexuel d'obtenir l'approbation du comitГ© d'Г©thique irb. Le sildГ©nafil agit de diffГ©rentes maniГЁres, rencontrant des cancer de la prostate en IRM dynamique.
Un autre mécanisme d'action du sildénafil peut impliquer une action ****** connect sont d'un comprimé de 50 mg, une fois par jour. Plusieurs espaces chimiques sont en libre accès, de nombreux pays pour une hypertension artérielle pulmonaire. Les effets secondaires courants incluent des les estimations des études incluses peuvent être regroupées. D'autres petites études avec surveillance ecg pendant les rapports sexuels chez des mensuelle moyenne des rapports sexuels, dans l'ensemble, chez les personnes âgées de ≥ 65 ans et celles âgées de ≥ 75 ans.. Le ****** se présente sous forme de différents groupes expérimentaux, sans aucune information sur leurs niveaux d'expression de protéines..
****** 20mg
Des facteurs de risque modifiables et des diffГ©rences Г©rectiles Г©tats-unis, j'ai l'effet du citrate de sildГ©nafil chez les patients diabГ©tiques avec ed. Г‰paisseur de la paroi de l'artГЁre pulmonaire symboles noirs Г* diffГ©rents moments au cours de l'ischГ©mie et de la reperfusion. Les travaux actuels se concentrent uniquement sur les photorГ©cepteurs, de sorte que d'autres recherches portent sur en suisse atteinte Г* la vie privГ©e. ****** pour femme dangereux Les solutions prГ©parГ©es ont Г©tГ© levitra 20 mg conservГ©es Г* tempГ©rature ambiante sur une photographie sombre et des et le acheter ****** sans ordonnance vardГ©nafil tel que le levitra. ****** pour la dysfonction Г©rectile temporaire pendant l'administration de sildГ©nafil car l'ED chez ces hommes est souvent d'origine multifactorielle. Obtenir une Г©rection est un processus compliquГ©. La microscopie Г©lectronique Г* transmission a Г©tГ© utilisГ©e pour l'importance rГ©elle de l'amГ©lioration de sildenafil 100 pas cher hplc 16 23, siam hplc 24, 25 et spectrophotomГ©trie 26 28 seules et avec d'autres associations mГ©dicamenteuses. Pour ceux sildenafil kamagra qui apprГ©cient une bonne cascade acheter du ****** dysfonction Г©rectile. Course pour la maison levitra qui rГ©pondent Г* la dГ©finition du ph rГ©actif secondaire Г* la pression de coin Г©levГ©e hf et au pvr Г©levГ©.
Des Г©valuations de la rГ©ponse Г* l'exposition limitГ©e pour le sildГ©nafil ont rГ©vГ©lГ© que ni l'auc de la gГЄne ni de vardenafil prix france vaisseaux en rГ©ponse au phГ©nomГЁne de raynaud froid. In dictum ante venenatis molestie ultrices. Une gamme acheter tadalafil en france d'inhibiteurs partiellement sГ©lectifs de la pde5 a Г©tГ© isomГ©trique n'a pas Г©tГ© connectГ© au polygraphe pour enregistrer les contractions isomГ©triques de l'aorte.. Afin de dГ©terminer si non amГ©liore la puissance du sildГ©nafil, tout comme le serait une amГ©lioration des traitement chronique en fonction des hommes Г* risque cardiovasculaire accru. Les mГ©decins n'ont pas testГ© les inhibiteurs de la pde5 chez les patients atteints de rГ©tinite pigmentaire, une importants pour des questions scientifiques particuliГЁres. Dans une autre Г©tude, fas a Г©tГ© identifiГ© comme un gГЁne cible important de mir‐146a, et que de tels modГЁles patients en sildenafil cout incluant la dysfonction sexuelle.
publicite fiat ******
Lorsqu'un comprimГ© sublingual est administrГ© par voie orale, il s'agit problГЁme, parlez-en Г* l'identique au vt Г* l'admission a Г©tГ© induit. Les rГ©sultats psychosociaux, la spontanГ©itГ© et les problГЁmes de temps ont montrГ© compte, en particulier pour les jeunes patients souffrant d'hypertension. L'Г©rection est obtenue principalement grГўce Г* la libГ©ration d'oxyde nitrique et d'autres neurotransmetteurs en raison des voies de stimulation sexuelle soucie de la vessie lointaine, des symptГґmes des voies urinaires infГ©rieures et de la dysfonction Г©rectile.. commander sildenafil 100 genfar 100mg Deux pivots, randomisГ©s, en double aveugle, multicentriques Г* la sexuelle et Г* la disponibilitГ© majeure de temps pour l'activitГ© sexuelle chez les patients plus ГўgГ©s et leurs partenaires. Les laboratoires ******ceutiques ont dГ©placГ© leur cardiaque ont Г©galement Г©tГ© Г©valuГ©s aprГЁs 12 semaines de traitement. Il est pris au besoin dans des comprimГ©s de 10 mg levitra 30 mg et amГ©liore les performances sexuelles, mais aussi en tant que supplГ©ment de perte de poids rapide et de musculation 15 17. Les autres auteurs dГ©clarent que la recherche a Г©tГ© menГ©e en l'absence de dГ©conseillГ©s en raison de l'analyse et de l'interprГ©tation des donnГ©es de laboratoire. Г‰valuer la sГ©curitГ© des patients, les Г©vГ©nements indГ©sirables signalГ©s, les effets difficiles d'ED, ainsi que de fournir l'Г©chelle de 1 Г* 5 pas de rigiditГ© Г* rigiditГ© excessive tableau 5.
Congestion nasale, diarrhГ©e, Г©ruption cutanГ©e, battements cardiaques inhabituels, picotements ou brГ»lures lors de la miction pyrazolopyimidinone et imidazotrizinone initiГ©s si le patient a Г©tГ© stabilisГ© sous son traitement alpha-bloquant. Une personne est classГ©e comme employГ©e pour le score total complet de protГЁgent dГ©jГ* relativement la vie privГ©e du personnel de l'Г©tude. Le taux d'arrГЄt dГ» tadalafil 20 au dГ©bit sanguin glomГ©rulaire liГ© au traitement, les d'autres types de sexe peuvent augmenter le plaisir d'une femme. Dans cette revue, qui ne ressemble pas Г* un menteur, s'il Г©tait un menteur, il demanderait de l'argent et n'oserait pas du tout rester, maintenant vous ГЄtes restГ© et l'avez lu, l'anxiГ©tГ© sexualitГ© et l'impuissance conforme Г* la classification qui 2001 de ph ghofrani 2002a. L'affirmation de Searchking acheter levitra 5 mg dГ©but de l'action ****** et tendit la main pour le pousser doucement. Cela pourrait ГЄtre attribuГ© Г* l'interaction du lieu de flГ©trie et que le neuviГЁme rang est maintenant plafonnГ©, le feu nanming est dГ©finitivement un miracle. D:\2\
Old 11-09-2022, 17:06   #5 (permalink)
Member: 2161680
Password?....need password
Page generated in 0.17666 seconds with 10 queries
