12-25-2013, 03:06 | #1 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2091578 Status: Offline Thanks Meter: 0 | irulu al101 boot loop i have this tablet and it cant pass the android loading screen i know this tablet is not very popular and because of this i havent found too much information about it i want to know if there is a way to go into recovery ive tried many buttons conbinations but without succes, i found a pdf file and downloaded some file to reinstall the software but i dont have the usb cable so i would rather get into recovery and make a factory reset, i hope someone can help me aout with this thanks in advance |
12-25-2013, 11:29 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | open the tab and put here some info here like board id touch id and cam id |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
12-25-2013, 19:07 | #3 (permalink) |
Member: 2091578 Status: Offline Thanks Meter: 0 | i cant open it because it isnt really mine but im triying to fix it for a friend and i dont want to risk on making any physical damage i found some info i hope it helps processor infortm x210 arm11 in the upper side it has a power button, a home button, menu button, volume button, usb host/device switch and under it has a reset button ive tried with it holding it or pressing it but nothing when i turn it on first thing that shows up is the irulu logo after that the android guy in that moment is when i would expect to see the recovery options (done it with other devices) and after that the android text (loading screen) |
12-25-2013, 19:22 | #4 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | you can check the tablet while connect to pc if pc ask for adb driver then its mean usb dubgging on from setting and you can easy wipe data using adb tool kit if pc not ask for adb driver then you must need to post here full details as i ask you in my fst post on this thread |
12-25-2013, 20:49 | #5 (permalink) |
Member: 2091578 Status: Offline Thanks Meter: 0 | ok if i connect it while it is on bootloop the pc starts looking for some drivers it shows the next 6 devices bc1003 tablet pc bc1003 tablet pc usb device bc1003 tablet pc usb device bc1003 tablet pc usb device usb storage decive usb composite device the only one that has an x on it (failed installation) is the bc1003 tablet pc edit: the tablet on the case shows irulu al101 name, but i searched the name bc1003 tablet pc and its the same Last edited by maur1c10; 12-25-2013 at 20:56. Reason: changed info |
12-25-2013, 21:11 | #6 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | usb storage decive its mean usb dubgging not on and you must need to update firmware to solved the problem |
12-25-2013, 21:15 | #7 (permalink) |
Member: 2091578 Status: Offline Thanks Meter: 0 | ok if i connect it to the pc while its off it turn on by itself and starts looking for the drivers but i think usb debugging mode is not activated, i would update it or reinstall the software if necessary im trying to find any tool and sw file by the way i guess it would be the same look for files from bc1003 tablet its supossed to be a flytouch, but in the case says irulu i was confused about it |
12-25-2013, 21:19 | #8 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | both hardware same so you can use one of them , |
12-25-2013, 21:26 | #9 (permalink) |
Member: 2091578 Status: Offline Thanks Meter: 0 | do you know where can i find the software? thanks again for your help i think a was able to find the conbination to enter recovery power+menu+back button but ip shows a fallen android with a red triangle |
12-26-2013, 02:27 | #10 (permalink) |
Member: 2091578 Status: Offline Thanks Meter: 0 | im sorry for the double post but the other one didnt allowed me to edit i used a tool called "phoenix card" and a img file thta i found for irulu and made the process but now the tablet wont even turn on, is there any img file that can be compatible with all a10 processor? so i can use it because now the tablet is dead |
12-26-2013, 06:43 | #11 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | yes you can but as i told you already in my old posts you must need to open tablet and post here the pcb id |
02-27-2015, 17:29 | #15 (permalink) |
Junior Member Join Date: Aug 2008
Member: 836374 Status: Offline Thanks Meter: 0 | need the firmware for the same one please i know is been some time... jejejee... but i have 2 of this kind of tablets... and i would like to have them working... will u send me the link of the firmware or the firmware instead... it will be so appreciated..... |
