12-25-2013, 17:10 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: india Age: 40
Member: 101117 Status: Offline Thanks Meter: 466 | ubislate 7c+ tested orignal flash file n flasher easy to flash just use this img file in this link. live suite which we use in micromax flashing.. here is link of file n flasher UBISLATE 7C+ Stock and flasher - Download - 4shared - kailash |
The Following 4 Users Say Thank You to kailash_gm For This Useful Post: |
01-02-2014, 18:17 | #6 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | there is 2 method you can apply one of them both working and tested - A working ROM Link [Password: esandroid] - Flashing Program Link - A Memory Card of atleat 512 MB - A PC/Laptop. Flashing Instructions 1) Extract PhoenixCard.rar by using Winzip or Winrar. 2) And extract it into same folder where the PhoenixCard is extracted. 3) Take a micro SD card and format it. 4) Insert the SD Card into laptop or PC by using SD Card jack. 5) Double click on PhoenixCard app into the folder of PhoenixCard. 6) A window will open and in the disk Box, select the Drive of your SD Card. 7) Now click on img File and select the Downloaded ROM IMG file. 8) Then click on Burn button. And it will show you some processing. 9) After completion this processing exit phoenixCard app and remove the SD Card from laptop/PC. 10) Switch of your device and insert that SD Card into the device and turn it on. 11) It will shows a progress bar on the centre of the display after completeion of his bar click ok and remove SD Card. 12) Start the device as normal. 2nd one here Flash File of Ubislate 7c+ find it first on >>> Ubislate7C+ what you need : Ubislate 7C+ which is stuck on android Ubislate 7C+ Drivers >>> 32Bit & 64Bit Cwm recovery for ubislate LINK >>> CWM Recovery Method: 1: Connect the tab to pc n install driver 2: Start the tab n let it show android icon or name 3: Flash Cwm recovery by clicking recovery for ics and follow the instruction 4: Copy the folder in the ubislate7c+ flash file zip to ur sd card 5: Insert the sd card in the Tab. 6: Click reboot to recovery. 7: Wipe data/system 8: Go to backup/restore 9: Restore 10: DONE ENJOY YOU HAVE SUCCESSFULLY FLASH UR TAB For Those with Forgotten Pattern Lock Method: 1: Connect the tab to pc n install driver 2: Start the tab n let it show android icon or name 3: Flash Cwm recovery by clicking recovery for ics and follow the instruction 4: Click reboot to recovery. 5: Wipe Data/system & wipe Cache 6: Go to Advance n wipe Dalvik 7: Reboot. 8: DONE ENJOY |
The Following 2 Users Say Thank You to Faheem Anjum For This Useful Post: |
01-06-2014, 15:27 | #8 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: CLOUD Age: 40
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Quote:
1st Method success touch working but camera or wifi not working 2nd Method give error restore faild | |
02-08-2014, 16:30 | #10 (permalink) | |
Freak Poster Join Date: Nov 2011 Location: surat in gujrat
Member: 1684564 Status: Offline Thanks Meter: 25 | thamkx sir Quote:
08-11-2014, 06:19 | #11 (permalink) |
Insane Poster Join Date: Jan 2009
Member: 953066 Status: Offline Thanks Meter: 7 | ubislate7c+ tab just win data showing and hang, sprite update error: fail to scan flash infomation sprite update error: current card sprite failed now hold the machine showing this matter how to solve problem |
09-19-2014, 13:15 | #12 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2260206 Status: Offline Thanks Meter: 0 | Compatibility Issue Hello Kailash, I appreciate the good work that you've done for the older ubislate devices here. I own the new Ubislate 7C+ EDGE tablet which is based on the A23 Family with a dual core cortex A7 processor clocked at 1.2 Ghz. Will my device be compatible with the ROM that you've provided? |
04-29-2015, 06:04 | #14 (permalink) |
No Life Poster Join Date: Dec 2012 Location: india mumbai
Member: 1847344 Status: Offline Thanks Meter: 300 | all will be ok just flash only 7c+ type 5 here is link Welcome to the ./downloads/Datawind (Courtesy of Mr fcuker)/7C Plus Edge/ folder of GsmHosting support area |
