Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Spookey box
Old 10-03-2014, 13:25   #16 (permalink)
Member: 2267800
Sonork: 100.1666959
Thanks Meter: 12
can't read oppo joy (R1001) in chinese android tab...
error is DL_failed_invalid_DRAM
thanks
Old 10-04-2014, 06:08   #17 (permalink)
Member: 1580119
Sonork: baby
Thanks Meter: 7
what is can't read samsung mediatex sir?
Old 10-04-2014, 15:59   #18 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
@abahwiranta/samadyo
Uninstall your spookey and delete all files in spookey folder and Re-install
do with slowly cause engine maybe work in progress...
Br,
ARD
Old 10-05-2014, 20:03   #19 (permalink)
cerja's Avatar
Member: 1389840
Sonork: 100.1627479
Thanks Meter: 114
good day, spokeybox team, explain how to read scarter files for better job in that module
Old 10-26-2014, 17:28   #20 (permalink)
madgoeslim's Avatar
Member: 1853929
Sonork: 1653495
Thanks Meter: 426
Originally Posted by .::ARD::. View Post
@madgoeslim
Re-install then press update module button -DONE !
Br,
ARD
I follow your instruction for about ten times, the problem still exist Sir... "kg-sp.exe" error...
Old 11-18-2014, 17:15   #21 (permalink)
Member: 661764
Thanks Meter: 28
cant disable rtas 9860.. supporting file not found. please try re-install this program or contact our technical support.
i try re-install many times but still same problem..
The Following User Says Thank You to budi_rm02 For This Useful Post:
Old 11-23-2014, 22:18   #22 (permalink)
xchanges's Avatar
Member: 2038882
Sonork: 100.1663803
Thanks Meter: 67
Hi I have a small problem, I buy from Asco GSM that Spookey Box and I download from the website spookeybox. com the software to use with my box.
Unfortunate I cannot use because is looking like partial desactivated. i try to update... nothing. I try to install v1.2.2.1 and update 1.4.4.1 and 1.4.4.2... nothing still desactivate... I install v 1.5.2.4 rev 1 which is working... all option is activated but don't know to recognize a lot of phones when I put check on samsung phones.... can you explain me why please?
Old 11-24-2014, 00:10   #23 (permalink)
Member: 919139
Sonork: sapim
speaks bracket which supports not available. what to do?
Old 01-15-2015, 18:01   #24 (permalink)
Member: 2265288
Please help me, after installing windows i have installed the spookey box and NET Framework 4.0. why did not blackberry modul open the file is still the same that i sent before?
Old 02-01-2015, 16:49   #25 (permalink)
Member: 2338994
hello I have a problem I installed spookey box but I n, m not happen, Register
Old 02-26-2015, 16:30   #26 (permalink)
Member: 1790061
Thanks Meter: 63
happened with the team spookey and muiro him went the charm ...
tell anything happened with zero new project developments ..
Old 02-26-2015, 19:11   #27 (permalink)
Member: 2168530
Thanks Meter: 5
Um projeto morto. eu joguei meu dinheiro fora com essa porcaria....
Old 03-12-2015, 17:18   #28 (permalink)
Member: 2356361
help please , spookey activation problem
user: -
status : 01-01-2001
Old 05-05-2015, 23:37   #29 (permalink)
Member: 2381928
hello guy can any one here help me with driver software for spookex box v1.5.2.4 and uart usb.
Old 05-06-2015, 16:03   #30 (permalink)
Member: 2209602
Thanks Meter: 48
dead product bro no support this boz......
gpg to be responsible this product..
Page generated in 0.20756 seconds with 8 queries
