Nokia X Android Based Nokia X Nokia X+ Nokia XL The Nokia X family is a range of new smartphones from Nokia introduced in 2014, running a forked version of Android |
06-01-2014, 17:56 | #1 (permalink) |
Freak Poster Join Date: Feb 2010 Location: Narayanganj, Bangladesh. Age: 36
Member: 1226253 Status: Offline Sonork: 1602755 Thanks Meter: 69 | nokia x flasher Download NOKIA X Flash Tool, an All-in-One tool to Flash System, Boot, Recovery & Fastboot – Details Posted by: Pradeep Neela in X May 11, 2014 1 Comment 348 Views While no one would have ever thought that NOKIA will someday be coming up with an Android smartphone, here comes the flasher which will help you to flash the system, boot, recovery and also one can easily flash the partitions. So after checking out the list of quick pre requisites mentioned below, lets proceed to check on what are the quick pre requisites first and then we will head over to the detailed procedure which will help you use the Nokia X Flashing tool. Quick Pre Requisites:
SMS – Use “SMS Backup & Restore app”,
Procedure to Use Nokia X flashing tool:
Note: If at all your Nokia X smartphone gets in the boot loop mode, then you need to turn off the device and then reapply the update from the start. To turn off you can long press the power button and repeat the whole process again.Do let us know in the comments section just in case if you face any issues as we will be more than happy to help you out. |
The Following 3 Users Say Thank You to ramjan_777 For This Useful Post: |
