NTool sneakpeak cooking degree : medium rare Code: RUNNING NTool 0.01 EDL mode not required. IMEI/BT/MAC change, which do not damage network. bootloader unlock. ..... reasonable cheap really soon |
Nice to see u here ;) |
Yes how to get this tool? |
b.r. Alex |
So good seeing both of you still working, and on the same post :) BR |
Great to see SE genius now in Nokia. I'm waiting for it :) |
How long wait for that ??? |
FRP supported ? ............ |
Anyone with setool2 credits can test NTool 0.02 https://mega.nz/#F!Qt0gmIhJ!IsPqnXMJB-TKQpxZq5aKQA 1 credit for flashing 1 credit for bootloader unlock generation supported any HMD smartphone - nokia 1,2,3,4,5,6,6.1,7,7 plus,8 so far supported : - flashing of original .NB0 files or original unpacked .NB0 !!! make sure you using proper firmwares for your phone model !!! - FRP reset - bootloader unlock signature generation !!! make sure you double check IMEI and SERIAL NUMBER BEFORE REQUEST !!! instructions to use signature : Code: install fastboot drivers for phone. - ALWAYS connect powered off phone !!! If phone in FASTBOOT mode - connect phone to cable, start operation, then press and hold volume up + power buttons until phone restart !!! |
can someone upload NTool 0.02 to other place? I cant open mega folder |
I have semi bricked Nokia 6 ta-1033 when client make ota update. I manage somehow to downgrade bootloader from 8.1.0 to 7.1.1 with adb sideload and now OST LA can start to program phone in FTM mode with .nb0 but process end with error that battery is to low and I cant charge battery from recovery, ftm or powered off phone When I try to flash with ntool phone need to be powered off, and when I connect powered off phone ntool do not detect phone even some driver is loaded for a short time and after this phone goes to recovery or stuck to android logo Any help why ntool cant detect phone @seba thanks for the link ;) |
drivers, included in ntool or in OST, should be installed. NTool will only detect phone if it in FASTBOOT mode and drivers are installed. HMD devices enter FASTBOOT mode automatically during reset. you can try another next trick : start operation, connect phone in recovery or stuck in android logo, press and hold volume up + power on until phone reset. btw, NTool v0.0022 released with support for flashing of NTool firmwares plus many interesting firmwares uploaded Code: ./Nokia1.Frontier.FRT: |
Thanks I'll try next phone because this nokia 6 I solved firmware problem with OST LA. First I flash twrp to phone then I charge phone because twrp have this ability and then I write firmware with OST LA |
