Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip 2
Old 07-23-2020, 15:36   #1 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,766
Smart-Clip2 v.1.38.02. Vendor/country/Model Repair for Kirin 970/710/980 and others
Smart-Clip2 Software v.1.38.02
Exclusive Huawei Solutions
1. First in the WORLD!
Released exclusive Repair features for devices based on HiSilicon Kirin 65x / Kirin 95x
/ Kirin 960 / Kirin 970 / Kirin 710 / Kirin 980:
• Change vendor
• Change country
• Change Model
Benefits:
• EMUI version does not matter
• Allows to convert DEMO units to full working phones
• Correct Repair data in OEM info zone
• Totally safe operation, because Smart-Clip2 makes auto-backup of original OEM info area
How to connect:
• No need to disassemble the phone with Smart-Clip2 software testpoint
• Also you may use hardware testpoint
Note for devices on Kirin 980: We do not recommend restoring OEM-info area from another phones. In
order to write data in OEM info zone correctly, please Repair Vendor/Country/Model and reflash the phone.
2. Improved Enable downgrade feature for models on HiSilicon Kirin 710 / Kirin 980
• This feature allows to downgrade firmware/ Android version of the phone
3. Significantly improved Software Testpoint feature for models on HiSilicon Kirin 95x.
4. More features will be added, step-by-step.
FULL List of features exclusively supported by Smart-Clip for devices on Kirin 710/970/980:
Service:
• SOFTWARE TESTPOINT (service without disassembling)
• Direct network unlock
• Remove Huawei ID
• REMOVE FRP
• Get full device info
Repair:
• Repair and Change Vendor / Country / Model
• Read / Write OEM INFO
• Rescue mode entering
• Load Fastboot / Backdoor open
• Write original Huawei board (factory) flash files in *.xml or Smart-Clip2 format
Write Flash:
• Write original FullOtaUpdate / SD_Update files
• Enable Downgrade / Change firmware
• Flash in Upgrade or Fastboot mode
You can find the list of supported Huawei devices HERE
Both Pack 5 and Pack 6 have to be activated to use these exclusive features.
Download Smart-Clip2 Software v.1.38.02
The Following 11 Users Say Thank You to GSM_Support For This Useful Post:
Old 07-23-2020, 16:04   #2 (permalink)
Member: 220595
Thanks Meter: 355
•Change vendor
•Change country
•Change Model
Benefits:
•EMUI version does not matter
•Allows to convert DEMO units to full working phones
•Correct Repair data in OEM info zone
•Totally safe operation, because Smart-Clip2 makes auto-backup of original OEM info area
How to connect:
•No need to disassemble the phone with Smart-Clip2 software testpoint
•Also you may use hardware testpoint
•This feature allows to downgrade firmware/ Android version of the phone
Service:
•SOFTWARE TESTPOINT (service without disassembling)
•Direct network unlock
•Remove Huawei ID
•REMOVE FRP
•Get full device info
Repair:
•Repair and Change Vendor / Country / Model
•Read / Write OEM INFO
•Rescue mode entering
•Load Fastboot / Backdoor open
•Write original Huawei board (factory) flash files in *.xml or Smart-Clip2 format
Write Flash:
•Write original FullOtaUpdate / SD_Update files
•Enable Downgrade / Change firmware
•Flash in Upgrade or Fastboot mode
I believe IMEI repair it is one step away .
Great job
Enviado desde mi SM-G975U1 mediante Tapatalk
Old 07-23-2020, 17:05   #3 (permalink)
Member: 328688
Thanks Meter: 2,282
Good update waiting add imi reapir options also keep up good work
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post:
Old 07-23-2020, 20:09   #4 (permalink)
Member: 2711874
Sonork: 100.650600
Thanks Meter: 462
Good update..Keep it up
The Following User Says Thank You to zeeshan ali 786 For This Useful Post:
Old 07-24-2020, 00:35   #5 (permalink)
Member: 388862
Thanks Meter: 107
Good update !!!!!!!!!
Can add Kirin 980 ???????????
Old 07-25-2020, 05:38   #6 (permalink)
Member: 2902804
Sonork: 100.1660513
Thanks Meter: 928
the best
• Change vendor
• Change country
• Change Model
Old 07-25-2020, 07:32   #7 (permalink)
Member: 1093509
Thanks Meter: 5
Good update..Keep it up ..waiting for more updates
Old 07-25-2020, 17:37   #8 (permalink)
Member: 2552533
Thanks Meter: 93
Boom Boom update thnx team keep it up
Old 07-27-2020, 19:17   #9 (permalink)
Member: 2963183
good update thanks
The Following User Says Thank You to lekan2020 For This Useful Post:
Old 07-29-2020, 05:20   #10 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 561
Nice update smart-clip2
The Following User Says Thank You to Malik Shani G For This Useful Post:
Page generated in 0.20900 seconds with 8 queries
