Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 02-22-2018, 22:44   #1 (permalink)
Member: 2309595
Thanks Meter: 112
LS 997 Unlock Success and Fix Sevices Dsiabaled
Using Version...1.0.0.0054
Selected Model GT-I5510
Selected Task LG SPRINT UNLOCK
Searching ADB device Please wait..
Device Detected...
SELinux := Enforcing
model:= LG-LS997
Androids Version:= 7.0
Description Version:= elsa_spr_us-user 7.0 NRD90M 180041051d267 release-keys
Platform:= msm8996 [ elsa ] [ ]
Baseband:= MPSS.TH.2.0.1.c3-00027-M8996FAAAANAZM-1.79643.1.106740.1
Factory Ver := LGLS997AT-00-VZVC-SPR-US-JAN-04-2018-ARB01+00
Model & Firmware Ver := LS997ZVC
Security Patch := 01-01-2018
Simstatus:= ABSENT
ANDROID-ID = LGLS9975242fd0b_00005050D6
Device is not rooted
LG Sprint Unlocking Started..
Please Wait while...
Loader Ok Starting task...
MSL/SPC IS := 880011
Direct Unlock Success..
Restart Phone if not auto...
Total Time Take...00:01:57
Log Saved
To fix services disabled then this is the second step
Via command shell
adb shell am start com.lge.networksettings/com.lge.networksettings.MobileNetworkSettings
The Following User Says Thank You to matthew.ebay For This Useful Post:
Old 02-23-2018, 01:26   #2 (permalink)
luisy's Avatar
Member: 2352896
Thanks Meter: 116
I have did this steps and with the command only shows network modes, even if you choose global it takes signal and drops away and again and again.
Where do you live? I live in Cuba.
Thanks
The Following User Says Thank You to luisy For This Useful Post:
Old 02-23-2018, 09:15   #3 (permalink)
Member: 92260
Thanks Meter: 843
Thanks
I've found some more activities you may want to try.
Simply copy and paste the lines below one by one to the end this command line without the <> bracket:
adb shell am start <insert_the_activities_below_here>
com.lge.networksettings/com.lge.networksettings.Mobile4GSettings
com.lge.networksettings/com.lge.networksettings.MobileNetworkSettingsForSP CS
com.lge.networksettings/.CDMANetworks filter
com.lge.networksettings/.LteGsmUmtsSettings
com.lge.networksettings/.ManualCSGSelection
com.lge.networksettings/.MobileNetworkSettings
com.lge.networksettings/.MobileNetworkSettingsForCDMA
com.lge.networksettings/.MobileNetworkSettingsForGLOBAL
com.lge.networksettings/.msim.IccLockSettings
com.lge.networksettings/.msim.MSimMobileNetworkSubSettings
com.lge.networksettings/.NetworkSetting_LGU
com.lge.networksettings/.NetworkSettingGSM
com.lge.networksettings/.SelectRoamingNetwork
com.lge.networksettings/.SystemSelect
Please report back if you find anything interesting.
The Following User Says Thank You to BillA For This Useful Post:
Old 02-23-2018, 19:50   #4 (permalink)
luisy's Avatar
Member: 2352896
Thanks Meter: 116
What I've found interesting is in
this commands are expecting for "SU" permision.
And in the app LGHIDDENMENU 1.7(is the last version I know) it doesn't show IOT(CDG2), it is like same bug boxes are using to select "LAB NETWORK". It doesn't show anymore.
I have found this option using other way, but it ask for root. Maybe this is the way to get it unlocked.
The Following 2 Users Say Thank You to luisy For This Useful Post:
Old 02-23-2018, 19:51   #5 (permalink)
Member: 2309595
Thanks Meter: 112
You should check to see your QCN is ok. I had a phone have that problem before
Thanks
Old 02-23-2018, 19:56   #6 (permalink)
luisy's Avatar
Member: 2352896
Thanks Meter: 116
QCN is fine, cellphone is new, I have more than one.
Old 02-23-2018, 21:12   #7 (permalink)
Member: 2309595
Thanks Meter: 112
check the modem. flash with different firmware and see what happened.
It should be software problem not the hardware
Old 02-23-2018, 22:51   #8 (permalink)
luisy's Avatar
Member: 2352896
Thanks Meter: 116
Do you have an older modem file from this phone?
Old 02-24-2018, 01:34   #9 (permalink)
Member: 92260
Thanks Meter: 843
IF you can root the phone then try sending as "su" command:
adb shell su -c am start <insert_the_activities_below_here>
Old 02-24-2018, 01:39   #10 (permalink)
luisy's Avatar
Member: 2352896
Thanks Meter: 116
Any idea to root this phone in this version?
Old 02-24-2018, 04:50   #11 (permalink)
Member: 2309595
Thanks Meter: 112
Sorry I don't. Modem can extract or flash only modem in octopus. Try to find kdz in internet.
MAKE SURE YOU FLASH THE RIGHT ONE with right security . wrong one can hard brick the phone
I hard brick my H918 by accident
I'm pretty sure it's QCN. I will try to upload the QCN for you tomorrow
Old 02-24-2018, 15:23   #12 (permalink)
luisy's Avatar
Member: 2352896
Thanks Meter: 116
Ok, I will wait for your file.
Old 02-24-2018, 19:11   #13 (permalink)
Member: 2309595
Thanks Meter: 112
send to your inbox. Let me know if it work out for you
Old 02-24-2018, 20:12   #14 (permalink)
Member: 2450214
Thanks Meter: 106
i have did this steps and with the command only shows network modes, even if you choose global it takes signal and drops away and again and again.
Where do you live? I live in cuba.
Thanks
i have this drop signal after a fews secs too.
Happen after unlock.
I have done two and they both behave the same.
Currently on 7.0 zvc
have mine for 4months now.
Old 02-24-2018, 20:17   #15 (permalink)
Member: 2309595
Thanks Meter: 112
That was weird, mine work fine. Although I didnt have the phone for test long enought but I didnt see any drop signal for the 5 minutes before the customer left
Page generated in 0.25296 seconds with 8 queries
