11-11-2016, 20:46 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Cali Colombia Age: 43
Member: 181405 Status: Offline Thanks Meter: 249 | G925FXXS4DPIJ/G925FOXX4DPH1 write cert ok USB Selected Task SAM CERT WRITE USB ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := G925F VER := G925FXXS4DPIJ/G925FOXX4DPH1/G925FXXU4DPHF/G925FXXS4DPIJ Phone IMEI := 00000000000000 Default MSL NO NEED RESET EFS... MSL Autho Pass.. Update IMEI Ok.. SKEY := 0346 EXYNOS Type Detected.. Checking imeicert... IMEI-1 CERT PASS.. Fixing FTM ok.. Repairing finish. !!! SUCCESS !!!! Total Time Take...00:03:37 Log Saved |
The Following User Says Thank You to hector bermudez For This Useful Post: |
11-13-2016, 15:26 | #2 (permalink) |
No Life Poster Join Date: Mar 2004 Location: esenler sevgiiletişim TR Age: 58
Member: 60560 Status: Offline Sonork: 100.89085 Thanks Meter: 134 | GCKEY PRO SUCCES..Not write any box is that operation ) ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := G925F VER := G925FXXS4DPJL/G925FOLB4DPH1/G925FXXU4DPIS/G925FXXS4DPJL Phone IMEI := 00000000000000 Default MSL NO NEED RESET EFS... MSL Autho Pass.. Update IMEI Ok.. SKEY := 0346 EXYNOS Type Detected.. Checking imeicert... IMEI-1 CERT PASS.. Fixing FTM ok.. Repairing finish. !!! SUCCESS !!!! Total Time Take...00:03:26 Log Saved |
11-17-2016, 15:27 | #3 (permalink) | |
Junior Member Join Date: Mar 2013
Member: 1898019 Status: Offline Thanks Meter: 1 | Quote:
11-17-2016, 15:44 | #4 (permalink) | |
Member: 1898019 Status: Offline Thanks Meter: 1 | patch cert, meidcert write, imeicert write, imeicert write usb, adb failed :'( any solutions please Quote:
11-18-2016, 01:54 | #6 (permalink) | |
my phone has drk issues, i already fix it. but in some AP files, it didnt show infos about imei, and *#0*# cant show up. why? some software issues or what? so i cant change to uart mode by pressing *#7248# and where i can get the combination files? Code: 1 if phone have 3500000 imei go to step 3 2 connect in normal mode use modem port in port list samsung tab select exynos unlock press start. 3 connect in download mode open odin flash engineering COMBINATION firmware for your model and version matching to it. 4 select box cable in list via scan port. select option IMEICERT Write (dial *#0*# replug plug c3303k cable.) or IMEICERT Write_USB for modem port press start. 5 check drk with readinfo uart or drk repair (dial *#0*# replug plug c3303k cable.) or drk repair adb. | |
11-18-2016, 05:37 | #7 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello phone have bad efs and csc. Use exynos efs reset with eng sboot. reflash stock full firmware+csc same version which on phone base on sn. root phone to bypass drk issue. make readinfo uart bypass knox imeicert write usb and select modem port and cert. |
The Following User Says Thank You to stanner_austin For This Useful Post: |
11-18-2016, 06:22 | #8 (permalink) | |
and then it became DRK issues, i already try many things and got this result. if i tried flash BL it became fail everytime. so i just can reflash with 3 files, AP CP & CSC. i didnt get the good BL files till now.. and this morning i tried reflash it with combination file (factory binary) and after finish the phone cant boot up, it shows Code: ASV TBL VER = 15 ASV TBL VER2 = 2070 ASV big:9 LITTLE:9 G3D:10 MIF:9 INT:9, CAM_DISP:9 | |
11-18-2016, 13:13 | #9 (permalink) |
Member: 1898019 Status: Offline Thanks Meter: 1 | now i got the sn after exynosefs_reset 05157d***** and imei still 35000000*** but cant do these last step Code: bypass knox imeicert write usb and select modem port and cert. here is the logs - many thanks Last edited by fxjk; 11-18-2016 at 13:22. |
11-18-2016, 13:40 | #10 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @fxjk Hello Issue is "readinfo uart" which is need before bypass knox. Bypass log you posted is fail log if you read you will find solution in log already. "Please accept root in phone.." If you still cant' solve contact me on skype i may need to check phone over team and your issue to find out exact reason why not working for you. btw are you sure you aware of readinfo uart using ? its need FTDI box any and c3303k cable ? |
11-21-2016, 05:58 | #11 (permalink) |
Member: 1898019 Status: Offline Thanks Meter: 1 | after a looong loooooong way to gooo.. finally Code: Using Version...1.0.0.0040 Selected Port VCP0 = COM27 Selected Model SM-G925F Selected Task SAM CERT WRITE USB ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := AT+SW VER := AT+SWVERSION=1,0 Phone IMEI := 00000000000000 Device Knox Warranty is := Void Default MSL NO NEED RESET EFS... MSL Autho Pass.. Update IMEI Ok.. SKEY := 0346 EXYNOS Type Detected.. Checking imeicert... IMEI-1 CERT PASS.. Wifi_mac := 2C0E3D02215B Wifi_mac update ok. Fixing FTM ok.. Repairing finish. !!! SUCCESS !!!! Total Time Take...00:03:35 Log Saved good job, GCProKey Really Great ! |
The Following User Says Thank You to fxjk For This Useful Post: |
