Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 02-07-2017, 21:46   #1 (permalink)
Member: 2598737
Thanks Meter: 4
Question SM-G930P FRP Failed(success)
I'm using the software version 47 of GC pro software.
Phone's firmware: G930PVPS4APK1
When i start the remove frp job, i get a success message but the problem is that nothing happens, the google lock is not removed.
Why frp removal does not work on newer firmware versions ?
Old 02-08-2017, 08:54   #2 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@dorin1993
Hello
Can you tell me how we guess without log what method,option used ?
Old 02-08-2017, 15:14   #3 (permalink)
Member: 2444830
Thanks Meter: 162
You supposed to let it boot then it will let you go to the home screen then go to settings then factory reset it, keep in mind that this is just a bypass you have to factory reset for permanently removing FRP....
Sent from my iPhone using Tapatalk
Old 02-08-2017, 19:11   #4 (permalink)
Member: 2598737
Thanks Meter: 4
Using Version...1.0.0.0041
Selected Port ssudmdm0001 = COM12
Selected Model SM-G930P
Selected Task SAMSUNG FRP Remove
Searching phone...
Device Found..
MODEL=SM-G930P;UN=CE011601A903C63C03;CAPA=32;VENDOR=SAMSUNG ;FWVER=0003;PRODUCT=KLUBG4G1CE-B0B1;PROV=PASS;
Init ok..
FRP Removed.
!!! Success !!!!
Restart Phone if not auto...
Total Time Take...00:00:14
Old 02-09-2017, 19:51   #5 (permalink)
Member: 2598737
Thanks Meter: 4
No answers at all, any way to remove FRP on s7 Sprint ???
Old 02-10-2017, 08:45   #6 (permalink)
Member: 49752
Thanks Meter: 6,085
@dorin1993
Hello
You are using wrong FRP solution for s7 phone.
Read helpfile name updatexx\helpfiles\Details help on FRP.txt for samsung 2016 phones.
Insort:
G930T root at support work on G930P then use frp remove adb will clear frp just need to reflash stock boot.img to get phone working fully.
The Following User Says Thank You to stanner_austin For This Useful Post:
Old 02-10-2017, 18:24   #7 (permalink)
Member: 2598737
Thanks Meter: 4
Thanks m8.
Using Version...1.0.0.0042
Selected Task FRP REMOVE ADB
Searching ADB device Please wait..
Device Detected...
Security:= OFF Unsecure device
model:= SM-G930P
Androids Version:= 6.0.1
Description Version:= heroqltespr-user 6.0.1 MMB29M G930PVPS4APJ2 release-keys
Platform:= msm8996 [ qcom ] [ msm ]
Baseband:= G930PVPS4APJ2
VER:= G930PVPS4APJ2/G930PSPT4APJ2/G930PVPS4APJ2/G930PVPS4APJ2
Carrier := SPR_USA
EFS CSC := SPR
AP UART Status := Disable.
Simstatus:= ABSENT
ANDROID-ID = cea22aab_0000DB71B1
Device is Unsecure Rooted
ANDROID FRP REMOVE ADB STARTED...
!!! Success !!!!
Restarted phone...
Total Time Take...00:00:03
Old 02-11-2017, 00:46   #8 (permalink)
Member: 2598737
Thanks Meter: 4
Unlock also works on PJ2 versions or later but it also requires this unsecure root. It is very difficult to get it right, a very high precision is required.
Selected Task SAMSUNG SPRINT UNLOCK
Device Detected...
model:= SM-G930P
Carrier := SPR_USA
EFS CSC := SPR
Simstatus:= ABSENT
ANDROID-ID = cea22aab_000056EB2C
SAMSUNG ALL SPRINT UNLOCKING STARTED...
Checking Data...
Waiting for Loader...
Loader Ok...
No device found Please make sure DIAG PORT is selected..
Direct Unlock Success...
!!! Success !!!!
Restart Phone Manually if not done auto...
Total Time Take...00:00:24
Page generated in 0.18543 seconds with 8 queries
