Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 02-19-2016, 20:17   #1 (permalink)
Crazy Poster
Member: 40884
Thanks Meter: 4
Does GC pro key support S6 SM-G920F? (DRK problem)
I have a problem with the DRK file. I get this error message on the recovery mode screen 'dm-verity verification failed... need to check DRK first...' and the phone hangs on the Samsung logo after flashing 4 file ROM.
The phone goes through when rooted but does not get signal, always says 'emergency calls only'. Sometimes the service codes i.e. *#06#, *#0808# etc don't work.
The IMEI is working fine.
I have searched google and some results tell me that I flashing a cert file using a GC Pro will repair the DRK error.
What I need to know before I buy this product is if this model (SM-G920F) is supported and have others fixed this problem using this method? My firmware is 5.1.1.
Thanks in advance!
The Following User Says Thank You to rafick For This Useful Post:
Old 02-20-2016, 10:34   #2 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
Hello
You can write imei cert on any samsung with gcpro.
However you need reset efs & eng sboot due to phone warranty is void and all phone have new modems with warranty check.
DRK repair is for device root key its have nothing to do with network. its just helpful on boot loop not on network. its do not need reset or eng sboot or anything.
about code 06 not work is posted by us many time use search.
Old 02-20-2016, 19:11   #3 (permalink)
Member: 2202707
Sonork: whatsapp +59170073722
Thanks Meter: 212
Hello I have a question.
DRK G925L repair is supported 5.1.1 OJ2 .... ???
I await your prompt response Thanks
Old 02-20-2016, 21:37   #4 (permalink)
Member: 1674736
Thanks Meter: 8
You need factory firmware to do that with gc pro
Old 02-20-2016, 21:38   #5 (permalink)
Member: 1674736
Thanks Meter: 8
Is the phone still booting to the system ?
Page generated in 0.18078 seconds with 9 queries
