11-24-2016, 05:27 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | G920TUES5DPI2 Unlocking not success Code: Hello All logs you posted is fail due to wrong step performed without reading helpfile. Step 1, GCPro do not support ss333 cert read yet. you can backup nv_data with adb unlock saved in backup\android idxxxx\ for later use. or use other tool to read cert. Step 2, Exynos efs reset need phone to be in download mode,select modem port not UART port and engineering bootloader. which at mega support link REPAIRFILES folder Step 3, Write nv data or cert file depend on your choice, both possible with gcpro. check if all ok imeicert, and imei, Step 4, Drk repair and tmobile unlock. Post results. __________________ Best Regards GCPro_Team step 2 i can't reflash with G920P_VPU4API2_ENGSBOOT.tar in Repair file folder of Mega link Step 3 ok Step 4 fail with Tmobile unlock Code: Using Version...1.0.0.0040 Selected Model SM-G920T Selected Task SAMSUNG T-MOBILE UNLOCK Searching ADB device Please wait.. Device Detected... model:= SM-G920T Androids Version:= 6.0.1 Description Version:= zeroflteue-user 6.0.1 MMB29K G920TUES5DPI2 release-keys Platform:= exynos5 [ samsungexynos7420 ] [ SHANNON333 ] Baseband:= G920TUES5DPI2 VER:= G920TUES5DPI2/G920TXAR5DPI2/G920TUES5DPI2/G920TUES5DPI2 Carrier := XAR_USA Network Mode := LTE Simstatus:= NETWORK_LOCKED ANDROID-ID = 1215fc75adb63f05_0000E278B8 SU Version..2.74:SUPERSU Device is Secure Rooted..uid=0 System Permission is Read/Write... SAMSUNG ALL T-MOBILE UNLOCKING STARTED... Checking Data... Waiting for Loader... Loader Ok... dbg...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 !!! Fail !!!! Restart Phone Manually if not done auto... Total Time Take...00:00:19 Log Saved What's problem? Pls help me |
11-24-2016, 06:03 | #2 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
The Following User Says Thank You to CHANDARAKK For This Useful Post: |
11-24-2016, 09:39 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,086 | @089999945 Hello You did not read correct all steps. You can not flash G920P eng bootloader to G920T. need to use G920P eng sboot. You must reset exynos efs in download mode. You must reflash stock same versions sboot Only. (in your case G920TUES5DPI2) You must root and bypass knox and use imeicert cert or nv data if you have backup of original. You Can now use tmobile unlock and it will be success now. |
The Following User Says Thank You to stanner_austin For This Useful Post: |
11-24-2016, 10:08 | #4 (permalink) | |
i think he do wrong any step i will help him more because he the same country of mind cambodia | |
11-24-2016, 11:22 | #5 (permalink) | |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote:
