G925t 6.0.1 baseband unknow...how fix it? Using Version...1.0.0.0039 Selected Model SM-G925T Selected Task SAM Readinfo ADB Searching ADB Devices... Device Detected... model:= SM-G925T Androids Version:= 6.0.1 Description Version:= zeroltetmo-user 6.0.1 MMB29K G925TUVU4EPF1 release-keys Platform:= exynos5 [ samsungexynos7420 ] [ ] Warning Baseband is Unknown or damaged.... VER:= G925TUVU4EPF1/G925TTMB4EPF1/G925TUVU4EPF1 Carrier := TMB_USA Network Mode := LTE Simstatus:= NOT_READY ANDROID-ID = 06157df62da28415_0000C05696 Detected su binary at /xbin Detected su binary at /bin SU Version..2.74:SUPERSU Device is Secure Rooted..uid=0 System Permission is Read/Write... Total Time Take...00:00:27 Log Saved |
wipe efs to see if u can reset the imei to 35000000000000000000006 |
flash a combination file |
How did you root it? With cf-autoroot? I haven't done one in about 10 days but from memory it only supports PD1 and anything higher I did had no baseband too. If you root you can do what you need to do but then you just need to flash PF/PG/PH modem back after finished and good to go. |
cf-autoroot can root this phone |
Now verson flash slove problem |
first u must repair baseband with reset efs baseband will be ok. if ur knox is void, do bypass knox then write cert usb with uart kabel. |
