08-05-2016, 21:51 | #1 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: Inside Samsung Pocket Age: 40
Member: 489331 Status: Online Thanks Meter: 1,141 | G928T PG1 Cert Write !!! SUCCESS !!!! Quote:
G928T PG1 Cert Write !!! SUCCESS !!!! | |
The Following User Says Thank You to raulka2003 For This Useful Post: |
08-08-2016, 15:04 | #4 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: Dominican Republic Age: 49
Member: 92317 Status: Offline Sonork: 100.1591991 Thanks Meter: 223 | Quote:
ok but i unlocked and reset mls for write a cert and ask reset msl or eng-sboot write and show this MSL autho fail CustomKernal Error use ENG SBOOT OR ENG KERNEL Must flash eng sboot or aboot depending on phone os..Engineering file is also known as COMBINATION FLASH or Factory Application firmware. FAxx br cdmagsm03 Last edited by cdmagsm03; 08-08-2016 at 15:10. | |
08-08-2016, 15:11 | #5 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @cdmagsm03 Hello This is another issue if phone is warranty void must flash eng sboot its have nothing to do with msl reset. Also please when ask question or help always post your log else we can't see what issue you facing or its really issue or you are not using as gcpro helpfile advised. |
08-08-2016, 15:26 | #6 (permalink) |
Member: 92317 Status: Offline Sonork: 100.1591991 Thanks Meter: 223 | ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := G928T VER := G928TUVU3DPG1/G928TTMB3DPG1/G928TUVU3DPG1/G928TUVU3DPG1 Phone IMEI := 35256707472567 MSL Address:= R58H12DGXM RESET EFS FIRST OR USE MSL CODE... !!! FAIL !!!! Total Time Take...00:00:38 Log Saved Searching phone... Device Found.. MODEL=SM-G928T;UN=1115FB7B08A51405;CAPA=32;VENDOR=SAMSUNG;F WVER=0301;PRODUCT=KLUBG4G1BD-E0B2;PROV=FAIL; Init ok.. Samsung Exynos EFS Reset Success.. Samsung Exynos CPEFS Reset Success.. !!! Success !!!! Restart Phone if not auto... Total Time Take...00:01:53 Log Saved but not work on this phone br cdmagsm03 Last edited by cdmagsm03; 08-08-2016 at 15:35. |
08-08-2016, 15:47 | #7 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @cdmagsm03 Hello Your log is wrong did you read "exynos unlock" work over usb modem port ? Did you try "exynos unlock" with ur phone or not ? If you still can't understand please ask any one to help you. efs reset is no longer need due to exynos unlock can reset msl direct. no need to erase imei if msl is default just write imeicert. if you get warranty void error you must flash eng sboot. |
08-08-2016, 16:18 | #8 (permalink) |
Member: 92317 Status: Offline Sonork: 100.1591991 Thanks Meter: 223 | @stanner_austin Hello this is my problem and ask for this but still wait for help to get it warranty void error you must flash eng sboot. |
08-08-2016, 17:29 | #10 (permalink) |
Member: 489331 Status: Online Thanks Meter: 1,141 | Just reset msl via 1) exynos unlock option then 2)write cert using imeicert_write_usb knox need be 0 |
The Following 4 Users Say Thank You to raulka2003 For This Useful Post: |
08-10-2016, 00:10 | #13 (permalink) | |
Insane Poster Join Date: Nov 2014 Location: Sokovia
Member: 2300259 Status: Offline Thanks Meter: 8 | Quote:
same problem here. Anyone with a ENG SBOOT? Thanks... | |
08-11-2016, 22:52 | #14 (permalink) |
Insane Poster Join Date: Sep 2012 Location: MIAMI
Member: 1810649 Status: Offline Sonork: GunShoot Thanks Meter: 8 | Using Version...1.0.0.0035 Selected Port ssudmdm0000 = COM121 Selected Model GT-I5800 Selected Task SAMSUNG Exynos Unlock Phone Found Please Wait... Model := G928T Ver := G928TUVU3DPG1/G928TTMB3DPG1/G928TUVU3DPG1/G928TUVU3DPG SN := R58GB03VGP IMEI := 35256707334092 UNIQID := 0915F96588ED150 Unsupported Device or new security.DBG !!! Fail !!!! Total Time Take...00:00:47 Log Saved ?????????? |
08-27-2016, 05:30 | #15 (permalink) |
Freak Poster Join Date: Apr 2016
Member: 2554552 Status: Offline Thanks Meter: 21 | what i did wrong ? i already flash engsboot in AP Tab with odin and it still not work. Using Version...1.0.0.0035 Selected Port ssudmdm0000 = COM54 Selected Model SM-G928T Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := G928T VER := G928TUVU3DPG1/G928TTMB3DPG1/G928TUVU3DPG1/G928TUVU3DPG1 Phone IMEI := 35312307124382 Default MSL NO NEED RESET EFS... MSL autho fail CustomKernal Error use ENG SBOOT OR ENG KERNEL.. !!! FAIL !!!! Total Time Take...00:00:43 Log Saved |
