G928T PH2 Imei Repair Success power of GCPro G928T PH2 imei repair log: Quote:
im trying to do exynos unlock and it fails how did you do the cert write |
exynos efs reset -> write cert -> root -> drk repair |
unlocked SM-G928T 6.0.1 PH2 (IMEI GOOD ) (SN GOOD ) Security:= OFF Unsecure device model:= SM-G928T Androids Version:= 6.0.1 Description Version:= zenltetmo-user 6.0.1 MMB29K G928TUVS4DPH2 release-keys Platform:= exynos5 [ samsungexynos7420 ] [ SHANNON333 ] Baseband:= G928TUVS4DPH2 VER:= G928TUVS4DPH2/G928TTMB4DPH2/G928TUVS4DPH2/G928TUVS4DPH2 Carrier := TMB_USA EFS CSC := TMB AP UART Status := Enable Already. Network Mode := LTE Simstatus:= READY ANDROID-ID = xxxxxxxxxxxxxxxxxx Device is Unsecure Rooted SAMSUNG ALL T-MOBILE UNLOCKING STARTED... Checking Data... Waiting for Loader... Loader Ok... Direct Unlock Success... !!! Success !!!! Restart Phone Manually if not done auto... Total Time Take...00:00:13 Log Saved |
you can do it with out wipeing Write PG1 ENG with the OJ5 modem and just write cert : then flash matching boot and modem |
Exynos Unlock Fail I cant post log this forum says i cant post links but the log doesnt have links |
How do you reset efs !?!?!? Using Version...1.0.0.0038 Selected Port ssudmdm0000 = COM69 Selected Model GT-I5500 Selected Task SAMSUNG Exynos Unlock Phone Found Please Wait... Model := G928T Ver := G928TUVS4DPH2/G928TTMB4DPH2/G928TUVS4DPH2/G928TUVS4DPH SN := R58G91S897 IMEI := 35256707159473 UNIQID := 0815F835D8E5010 Unsupported Device..DBG LY1RDoAwCEOv5Mag26fTeI3e/xZSNGkIlEexi7YZg1iqaoxW5ldbOk5M+VEMegkacTJym9ikpxZ 9l5au0kwgSfWDW09wVNjD6IpEq2D7wTikBNpdAOjjBQ== Unsupported Device or new security. DBG LYzRDYBACENXkiNw3qdEb43uv4WlmpCmPEr9gS9kYlZrG4MLfm okZ8McrfRZmBtz9gtXuxCcQixN9Ymwv0I+ sZRlAfGNPNTkarU / yPpUwLYCgRgv DBG11..JYrBDcAgDANXqlNw3i3QNW7/LaqAZJ0t6+IhJhn4K9boxD4PFQxkpOoLTdywyjt2djzqSVe8eM mt3PED !!! Fail !!!! Total Time Take...00:00:21 Log Saved |
i had same iss with exynos efs reset on g928 t. ph2 buildsoftware stop. phone stuck on kies reciovery. had to root phone for repir drk now knox void (0x0020c) **sn wipe only |
Using Version...1.0.0.0038 Selected Port ssudmdm0000 = COM12 Selected Model SM-G928T Selected Task SAMSUNG ExynosEFS RESET Searching phone... Device Found.. MODEL=SM-G928T;UN=0715F73D2DE32F38;CAPA=32;VENDOR=SAMSUNG;F WVER=0301;PRODUCT=KLUBG4G1BD-E0B2;PROV=FAIL; Init ok.. Samsung Exynos EFS Reset Success.. Samsung Exynos CPEFS Reset Success.. WORKING PORTS FOUND !!! Success !!!! Restart Phone if not auto... Total Time Take...00:13:14 Log Saved phone stuvck in smartswitch mode after hard reboot redid the process flash fw same result |
@clippy165 Hello If exynos efs reset is not success. this mans phones have new bootloader which reject rest. GCPro have option to fix such issue "Flash_Mode_fix" no need to full flash just to out from flash mode. if warranty already void use root base reset efs button. if still not worked then its must be very new protection take time to support it. |
get this issue http://uploads.tapatalk-cdn.com/2016...04625c3ef1.jpg http://uploads.tapatalk-cdn.com/2016...9accd2a566.jpg Sent from my SM-G930U using Tapatalk |
I got the same issue flash pg1 sboot repair drk with gcpro flash ph2 firmware |
Phone can't be downgraded. Tried WChriseg and it did not work. When I load the OJ5 modem the phone shows it lost the baseband and when I try to write cert file with GCPro Key log Using Version...1.0.0.0038 Selected Port Com:22 Selected Model SM-G928T Selected Task SAM CERT WRITE USB ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := G928T VER := G928TUVS4DPH2/G928TTMB4DPH2//G928TUVS4DPH2 Can use only on damaged phone stop here. !!! FAIL !!!! Total Time Take...00:00:58 Log Saved |
