04-09-2017, 19:06 | #1 (permalink) |
Freak Poster Join Date: Feb 2016 Location: Cayman Islands
Member: 2529251 Status: Offline Thanks Meter: 275 | G930F FRP Removal 100% I recently got a G930F running android 7.0 with frp and Samsung account for removal. I looked high and low for eng boot or an adb activator and found nothing but files that caused boot loop or hanging. I then had to buy this file however it worked like a charm so i have decided to share it. Step 1. Put phone in DL mode connect to pc. Step 2. Extract file Step 3 Connect phone to pc open odin flash 4 files. The phone takes a while to boot with the firmware. If it takes more than 10 min please hard rest . Wipe system/cache and reboot. Once files are flashed adb will be activated. Use your favorite box I used GCPro with frp via adb, but i am sure z3x or octo will work. Please say thank and share Files are uploading will post in link below when done |
The Following 6 Users Say Thank You to cyc0d3d For This Useful Post: |
04-10-2017, 00:38 | #4 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
04-10-2017, 01:11 | #5 (permalink) |
Member: 2529251 Status: Offline Thanks Meter: 275 | The phone was on 7.0 . This is a full eng os that will downgrade to 6.0.1 with adb activated on start up. You will need to flash stock firmware 7.0 back when done. Sent from my SM-G930F using Tapatalk |
04-10-2017, 01:30 | #6 (permalink) |
Member: 2529251 Status: Offline Thanks Meter: 275 | Here is link for files. Please try and report back. https://mega.nz/#!rsZi0L4R!B_U6iXaOd...Cp4hDIrRWF_OT0 Sent from my SM-G930F using Tapatalk |
The Following 5 Users Say Thank You to cyc0d3d For This Useful Post: |
04-10-2017, 01:40 | #7 (permalink) |
Member: 930280 Status: Offline Thanks Meter: 1,183 | lol this call old method downgrad also engroot already public why u need wastime on upload just downgrad to PAW than engroot than reset frp anyway thanks u for spend time upload file am use PAW firmware very easy after to 7.0 |
