Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 02-20-2016, 13:27   #1 (permalink)
Member: 724190
Sonork: zabih
Thanks Meter: 16
SAM G920 DRK repair problme
sam g920 drk repair comport select but eror
Selected Port Com:8
Selected Model SM-G920F
Selected Task SAMSUNG DRK FIX
Started Samsung DRK Fix...
No reply on samsung mode.. DIAL *#0*# AND TRY AGAIN...
!!! Fail !!!!
Total Time Take...00:00:07
Log Saved
in new modele comport not working
Old 02-20-2016, 14:36   #2 (permalink)
Member: 1025079
Thanks Meter: 311
You need to use uart cable and make sure to follow the instruction.
Old 02-20-2016, 15:02   #3 (permalink)
Member: 724190
Sonork: zabih
Thanks Meter: 16
what instruction please help me i use urt cable c3300k
Old 02-20-2016, 15:08   #4 (permalink)
.:GSM-SRABON:.'s Avatar
Member: 2283947
Sonork: 100:1662279
Thanks Meter: 317
block BSI LINE from battery connector
Old 02-20-2016, 15:17   #5 (permalink)
Member: 724190
Sonork: zabih
Thanks Meter: 16
this is g920f internal battrey how to ?
Old 02-26-2016, 07:15   #6 (permalink)
Member: 2457641
Thanks Meter: 153
U might be selecting the wrong port. Hit scan port and select the uart port then retry drk repair.
Old 03-01-2016, 05:29   #7 (permalink)
Member: 1970235
Thanks Meter: 20
connect any box(z3x, oct,spt...). Scan port on tool GCProkey --> Select COM port Box --> On phone G920F press dial *#0*# (phone testmode) --> Connect phone via UART cable with box --> Click repair DRK on tool GCprokey.
Work 100%.
Page generated in 0.19070 seconds with 8 queries
