02-02-2018, 10:05 | #2866 (permalink) |
Junior Member Join Date: Sep 2016 Location: via giusepehdis 87
Member: 2624863 Status: Offline Thanks Meter: 1 | Using 1.23 Card verify ok... Card OsVer 0002 GCPro SN:= GCE890C068 GCPRO Activation := NOT ACTIVE Checking server connection... Enter registration details for GCPro... Checking card.. Please Update GCPro First,Then use Register GCPro.. Fail at activation please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...02-02-2018-10-03-19 Using 1.23 |
The Following User Says Thank You to huangfengming For This Useful Post: |
02-02-2018, 14:36 | #2868 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2684990 Status: Offline Thanks Meter: 1 | Please GcPro group unlock my card more than 20 days waiting solution Using 1.23 Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Reading Details.. Card Lock Reason := MzAyNMYHDVwMDaAsIzNjR1MnExNHAzdXU0tXE2MA This GCPro is not Allowed to UPDATE or Register, Contact reseller.. GCPro SN := GC68A005F9 Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...02-02-2018-16-34-22 Using 1.23 |
02-03-2018, 02:37 | #2870 (permalink) |
Junior Member Join Date: Dec 2017 Location: Mexico
Member: 2794637 Status: Offline Thanks Meter: 0 | Plis Help...!! Mi box block Checking server connection... Server access ok.. Card is Locked. Making sure card is locked or not.. ERROR 0x1_islocked Reading Details.. This GCPro is not Allowed to UPDATE or Register, Contact reseller.. GCPro SN := GCDABFD82C Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...02-02-2018-19-35-28 Using 1.23 Using 1.23 Checking GCPro Card Details... ERROR 0x1_islocked Card is Locked. Checking server connection... GCPro SN GCDABFD82C Card OsVer 0002 Checking security of card... Please unlock card before update.... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...02-02-2018-19-36-52 Using 1.23 |
02-03-2018, 06:10 | #2871 (permalink) |
Member: 2788740 Status: Offline Thanks Meter: 0 | Using 1.23 Card verify ok... Card OsVer 0003 GCPro SN:= GC0D5D71AD GCPRO Activation := NOT ACTIVE Checking server connection... Enter registration details for GCPro... Checking card.. This GCPro is not Allowed to UPDATE or Register, Contact reseller.. Fail at activation please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...02-02-2018-21-05-05 Using 1.23 |
02-03-2018, 15:09 | #2872 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1508073 Status: Offline Thanks Meter: 5 | can not register, pliss help me register Using 1.23 Checking GCPro Card Details... Card verify ok... Card OsVer 0000 GCPro SN:= GCA97ECD60 GCPRO Activation := NOT ACTIVE Checking server connection... GCPro SN GCA97ECD60 Card OsVer 0000 GCPRO Activation := NOT ACTIVE Server Reply Error := ERR_BAD_REQ Fail to get reply from server stage1. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...03-02-2018-19-13-49 Using 1.23 Last edited by baraka1976; 02-03-2018 at 15:17. |
02-03-2018, 15:55 | #2873 (permalink) | |
Member: 1508073 Status: Offline Thanks Meter: 5 | Quote:
Please contact GCPro_Team for more info ACTIVATION NOT POSSIBLE IF OS IS NOT 0003..0000 Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...02-02-2018-19-51-48 Using 1.23 Using 1.23 GCPro found... Card verify ok... Card OsVer 0000 GCPro SN:= GCA97ECD60 GCPRO Activation := NOT ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...02-02-2018-19-53-17 Using Checking server connection... Server access ok.. Making sure card is locked or not.. Card verify ok... Card OsVer 0000 GCPro SN:= GCA97ECD60 GCPRO Activation := NOT ACTIVE GCPro is NOT Locked,Please do not use this option again... Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...02-02-2018-19-54-06 Using 1.23 | |
02-04-2018, 15:32 | #2874 (permalink) |
Freak Poster Join Date: Jun 2015 Age: 33
Member: 2418095 Status: Offline Thanks Meter: 125 | Using 1.23 GCPro found... Card verify ok... Card OsVer 0003 GCPro SN:= GC2C81B84D GCPRO Activation := NOT ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-02-2018-22-30-05 Using 1.23 |
02-05-2018, 07:53 | #2875 (permalink) |
Member: 1508073 Status: Offline Thanks Meter: 5 | can not register, pliss help me registerUsing 1.23 Checking GCPro Card Details... Card verify ok... Card OsVer 0000 GCPro SN:= GCA97ECD60 GCPRO Activation := NOT ACTIVE Checking server connection... GCPro SN GCA97ECD60 Card OsVer 0000 GCPRO Activation := NOT ACTIVE Server Reply Error := ERR_BAD_REQ Fail to get reply from server stage1. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...03-02-2018-19-13-49 Using 1.23 |
02-05-2018, 14:06 | #2876 (permalink) |
Freak Poster Join Date: Feb 2012 Location: paris
Member: 1719301 Status: Offline Thanks Meter: 132 | update problem 3 GCPRO Activation := CARD IS ACTIVE Checking server connection... GCPro SN GCCB9C85BC Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card error fail to start security session....6982 Fail to start security session,This CARD CAN NOT be updated,DO NOT TRY MORE.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-02-2018-14-06-05 Using 1.23 |
02-05-2018, 14:37 | #2877 (permalink) |
Member: 1719301 Status: Offline Thanks Meter: 132 | in every occasion i m connected i post my update problem,what should i do?throw the box or buy another one?WHAT IS THE SOLUTION PLZ,i m confused and angry.why till v59 ubdate is abnormal,mr stanner i deserve answers. respects |
02-05-2018, 16:15 | #2878 (permalink) |
No Life Poster Join Date: Jan 2004 Location: U A E
Member: 50511 Status: Offline Sonork: 100.109684 Thanks Meter: 307 | Card verify ok... Card OsVer 0002 GCPro SN:= GCF6AE1029 GCPRO Activation := NOT ACTIVE Checking server connection... Server Reply Error := ERR_REDOWNLOAD_NEW_SETUP.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-02-2018-19-14-43 I have All ready Install last version 62 |
02-05-2018, 16:15 | #2879 (permalink) |
02-05-2018, 16:23 | #2880 (permalink) | |
why do not you sell a working device, who will contact me for help solve the problem with gsprokey 1 Using 1.23 Checking GCPro Card Details... Card verify ok... Card OsVer 0000 GCPro SN:= GCA97ECD60 GCPRO Activation := NOT ACTIVE Checking server connection... GCPro SN GCA97ECD60 Card OsVer 0000 GCPRO Activation := NOT ACTIVE Server Reply Error := ERR_BAD_REQ Fail to get reply from server stage1. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-02-2018-20-25-27 Using 1.23 2 Using 1.23 Please contact GCPro_Team for more info ACTIVATION NOT POSSIBLE IF OS IS NOT 0003..0000 Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-02-2018-20-25-57 Using 1.23 | |
