Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 02-15-2019, 04:00   #4201 (permalink)
Member: 1825967
Thanks Meter: 5
This GCPro is not Allowed to UPDATE or Register, Contact reseller
Hello, I bought this new box with your cables on eBay
You see that everything is new but I can not activate it and the seller does not respond.
Using 1.27
Reader := Generic USB Smart Card Reader 0
Card OsVer 0003
GCPro SN:= xxxxxxxxxx
GCPRO Activation := NOT ACTIVE
Checking server connection...
Enter registration details for GCPro...
Checking card..
This GCPro is not Allowed to UPDATE or Register, Contact reseller..
Fail at activation please contact support...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-02-2019-14-20-20 Using 1.27
Old 02-17-2019, 01:38   #4202 (permalink)
Member: 1825967
Thanks Meter: 5
I still can not use the box
Using 1.27
Reader := Alcor Micro USB Smart Card Reader 0
Card OsVer 0003
GCPro SN:= GCC4084xxx
Checking card..
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...16-02-2019-21-37-24 Using 1.27
Old 02-17-2019, 07:04   #4203 (permalink)
Member: 966403
Thanks Meter: 3
resellerr name: luckybuy2016
Reseller Website: weblink
Card Register "Log":
Using 1.27
Card OsVer 0003
GCPro SN:= GC4157710E
Checking card..
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...17-02-2019-00-59-19 Using 1.27
Old 02-17-2019, 11:15   #4204 (permalink)
Member: 1825967
Thanks Meter: 5
Reseller name: xiaofega0
Using 1.27
Card OsVer 0003
GCPro SN:= GCC40841F9
Checking card..
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...17-02-2019-07-12-58 Using 1.27
Old 02-17-2019, 20:16   #4205 (permalink)
Member: 2870594
Sonork: yoandyveronika
Thanks Meter: 26
please help my gcpro key is locked
Using 1.27
GCPro found...
session fail Card Locked..
Fail cardos Card Locked..
Fail to get card os read details...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...17-02-2019-21-14-59 Using 1.27
Old 02-17-2019, 20:27   #4206 (permalink)
Member: 2870594
Thanks Meter: 26
please help
Checking GCPro Card Details...
Fail to start session with card...
Please check your internet connection...Server certificate verify failed (the server certificate is expired or the cert's signature verification failed).
Check internet connection, not able to connect server...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...17-02-2019-21-25-40 Using 1.27
Old 02-18-2019, 04:29   #4207 (permalink)
Member: 1672289
Thanks Meter: 3
please helpme!!!
Using 1.27
Server access ok..
Making sure card is locked or not..
Reading Details..
Card Lock Reason := FcLBEcAwCAOwlQihpTyDbfYfKdeT3tB0DkIPvBCVSh0wbNFph8 CG/7inUS1R6ysQdgE=
GCPro SN := GC471ED7AC
Fail at unlock card please contact support...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...17-02-2019-22-24-42 Using 1.27
Old 02-18-2019, 10:14   #4208 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,068
@masterdroid
Hello
Use different internet without proxy and give me proper log.
@yammel
Hello
Please use update tool to update gcpro not unlock and your issue will be solved.
Old 02-18-2019, 14:47   #4209 (permalink)
Member: 1934838
pleace not use proxy not vpn not antivirus not firewall... win 7 64bit from cuba THANKS BROTHER
Using 1.27
Card OsVer 0003
GCPro SN:= GC43297104
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...18-02-2019-09-45-52 Using 1.27
Old 02-19-2019, 11:50   #4210 (permalink)
Member: 966403
Thanks Meter: 3
@stanner_austin : my seller said they will handle the activation so sorry for the bother.
@ fermin1989: you need to send screenshot of register log to your seller on ebay. if he doesn't answer create an "item not as described" case on him.
Old 02-19-2019, 11:50   #4211 (permalink)
Member: 966403
Thanks Meter: 3
Old 02-19-2019, 17:15   #4212 (permalink)
Member: 1592972
Using 1.27
Server access ok..
Reading Details..
Card Lock Reason := szC2NMIHLZwtDaEsY0dnQ2dnQxNXYycXcyM3F2cA
GCPro SN := GC3952A23A
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...19-02-2019-12-15-33 Using 1.27
Old 02-19-2019, 17:31   #4213 (permalink)
Member: 1592972
my card is locked
Using 1.27
Server access ok..
Reading Details..
Job finish
Old 02-20-2019, 17:39   #4214 (permalink)
Member: 1108881
Using 1.27
Reader := Generic EMV Smartcard Reader 0
GCPro found...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...20-02-2019-23-37-43 Using 1.27
Old 02-20-2019, 17:53   #4215 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,245
CONTACT GC SUPPORT on Skype . dont delete old logs and any thing
The Following User Says Thank You to Mohsin-* For This Useful Post:
Page generated in 0.41515 seconds with 8 queries
