Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 01-23-2019, 18:42   #16 (permalink)
mr.omphonx's Avatar
Member: 714648
Sonork: 1609640
Thanks Meter: 925
need for remove "please call me" sm-G950N
Old 01-24-2019, 01:33   #17 (permalink)
Member: 1815016
Thanks Meter: 74
Is there list of which LG models supported for screen lock remove? Or maybe which chipsets work, which Android versions etc?
Old 01-24-2019, 10:28   #18 (permalink)
Member: 881225
Sonork: 100.1678282
Thanks Meter: 80
sm-g737p unlock done but still lock
Old 01-24-2019, 12:55   #19 (permalink)
Member: 2763706
Thanks Meter: 60
good update, please keep it up..
Old 01-24-2019, 13:46   #20 (permalink)
Member: 2148129
Thanks Meter: 42
Using Version...1.0.0.0062
Selected Port LGE Mobile USB Modem #9 COM727
Selected Model GT-I5500
Selected Task Pattern Remove (EMEGENCY_MODE)
LG EMERGENCY GTALK Remove Started..
Checking Phone info..
Detected in EMP Mode..
Fail to get model..
Safe Gtalk Remove Success..
!!! Success !!!!
Restart Phone if not auto...
Total Time Take...00:00:23
Log Saved
Phone Model LG-H873 G6. Phone still screen Lock by patern
Old 01-24-2019, 15:07   #21 (permalink)
Member: 2148129
Thanks Meter: 42
Selected Task Enable ADB Bypass Locks
Searching Phone...
Sw Version =
LGH873AT-00-V15d-GLOBAL
IMEI =
355469081575233
Done Enjoy...
Total Time Take...00:00:01
Log Saved
IN ONE SECOND. WTF. GCpro you gofar this time
The Following User Says Thank You to chicofiebru For This Useful Post:
Old 01-24-2019, 15:08   #22 (permalink)
Member: 2148129
Thanks Meter: 42
After try with old method it fail. New method work. One second
Old 01-24-2019, 16:26   #23 (permalink)
Member: 1403950
Sonork: andrew713
Added lg q710ms unlock
Enviado desde mi SM-N900T mediante Tapatalk
Old 01-28-2019, 11:08   #24 (permalink)
faisal.u7's Avatar
Member: 1028120
Sonork: 100.1607216
Thanks Meter: 90
plz sir kindly clear boost mobiles sprint samsung unlock supported this update yes and no ?
Old 01-28-2019, 13:10   #25 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,086
@faisal.u7
Hello
Both is same.. sprint & boost.
Old 01-28-2019, 18:51   #26 (permalink)
Member: 1063583
Thanks Meter: 3
Hello!
Looking to buy GCpro dongle or Box. Can it repair/write IMEI for CPID SM-G96XU models?
Thank you!
Old 01-28-2019, 21:23   #27 (permalink)
Member: 1422878
Thanks Meter: 164
With this update can permanent unlock J327P Bit 4 U4?
Old 01-29-2019, 09:06   #28 (permalink)
Member: 49752
Thanks Meter: 6,086
@maksim78
Hello
No,We support CERT write only. including MSLCERT and other related certs.
@helpinterchange
Hello
Did you try on combination modem ? if fail sad its rsa base. Only G960,G965 supported currently on rsa base security.
Old 01-29-2019, 13:06   #29 (permalink)
Member: 1422878
Thanks Meter: 164
Originally Posted by stanner_austin View Post
@maksim78
Hello
@helpinterchange
Hello
Hi @stanner_austin
With combination Modem is only Temp Unlock
I need do it permenent unlock.
Old 01-29-2019, 14:55   #30 (permalink)
Member: 49752
Thanks Meter: 6,086
@helpinterchange
Hello
Are you talking for J327P ?
Are you sure you used new update without diag port without root after locking phone ?
Any method you use if client do ##786 still gona relock any sprint phone even officially unlocked.
The Following User Says Thank You to stanner_austin For This Useful Post:
Page generated in 0.17355 seconds with 8 queries
