Ok one other question, about the msl and if it's included in cert.. You mention the no root method require msl to be inside cert file, as mine are in plain note pad how do i know if msl is in there, is it auto calculated when gc pro key trys to write. I just hoping all certs i have, have the msl in them, why i ask what do i look for.. But as said im ordering your product also to show support of you and your work. And yes i always find adb wipe is better as you can do backup and restore with ease. Thanks again |
here is format you can use like this.. Quote:
Regards, Chevli GCPROKEY |
other more Using Version...1.0.0.0011 Selected Port ssudmdm0000 = COM229 Selected Model Samsung GSM Selected Task SAMSUNG ENABLE ADB SAMSUNG ENABLE ADB STARTED... Searching Phone... Phone Found Please Wait... Sending Loader... BASE(SM-N900) VER(N910CXXU1ANIF/N910CUWA1ANIF/N910CXXU1ANJ5/N910CXXU1ANIF) HIDVER(N910CXXU1ANIF/N910CUWA1ANIF/N910CXXU1ANJ5/N910CXXU1ANIF) MNC(103) MCC(732) PRD(SM-N910CZWECOM) SN(RF8FA13YH1R) IMEI(35502506) UN(CR2005602452A91) PN() CON(AT,MTP) LOCK(NONE) LIMIT(FALSE) SDP(RUNTIME) HVID(Data:196609,Cache:262145,System:327681) USER(OWNER)## Loader Ready.. Sorry not worked...0_ !!! Fail !!!! All job finish.. Restart Phone Manually before doing anything... Total Time Take...00:00:20 Log Saved |
Using Version...1.0.0.0011 Selected Port ssudmdm0000 = COM228 Selected Model Samsung GSM Selected Task SAMSUNG ENABLE ADB SAMSUNG ENABLE ADB STARTED... Searching Phone... Phone Found Please Wait... Sending Loader... BASE(SM-N900) VER(G800MUBU1ANH4/G800MUUB1ANH1/G800MUBU1ANH4/G800MUBU1ANH4) HIDVER(G800MUBU1ANH4/G800MUUB1ANH1/G800MUBU1ANH4/G800MUBU1ANH4) MNC(101) MCC(732) PRD(SM-G800MZWMCOM) SN(R58F90WX1SZ) IMEI(35584 UN(C16048FACF59E81) PN() CON(AT,MTP) LOCK(NONE) LIMIT(FALSE) SDP(RUNTIME) HVID(Data:196609,Cache:262145,System:327681) USER(OWNER)## Loader Ready.. Sorry not worked...0_ !!! Fail !!!! All job finish.. Restart Phone Manually before doing anything... Total Time Take...00:00:38 Log Saved thxs http://forum.gsmhosting.com/vbb/imag...ons/report.gif |
@GAMMAHIGH Make your own thread. and talk clear. do you want to enable ADB or reset efs ? for adb as i see loader report not worked. plz contact me on messangers to test new beta. for reset efs show us reset efs log. Regards, Chevli GCPROKEY |
@aev777 Hello its not what end user should worry. if you are enduser contact guy who give cert, msl etc. If you have any question regarding current update or other update please post. Regards, Chevli GCPROKEY |
i need write cert thxs |
Using Version...1.0.0.0011 Selected Port ssudmdm0000 = COM231 Selected Model Selected Task SAMSUNG ENABLE ADB SAMSUNG ENABLE ADB STARTED... Searching Phone... Phone Found Please Wait... Sending Loader... BASE(SM-N900) VER(G7105LUBUANA3/G7105LUBUANA3/G7105LUWAANA4) HIDVER(G7105LUBUANA3/G7105LUWAANA4/G7105LUBUANA3/G7105LUBUANA3) MNC(101) MCC(732) PRD(SM-G7105ZWLCOM) SN(RF8F905YZTB) IMEI(3526950) UN(C8W008D6EEA1F71) PN() CON(AT,MTP) LOCK(NONE) LIMIT(FALSE) SDP(RUNTIME) HVID(Data:196609,Cache:262145,System:327681) USER(OWNER)## Loader Ready.. Sorry not worked...6_Q19CXzREXzQ5X0NfQl82 !!! Fail !!!! All job finish.. Restart Phone Manually before doing anything... Total Time Take...00:00:30 Log Saved |
@johnboy38 Hello. will be great if you post success log at here. http://forum.gsmhosting.com/vbb/f922...29/index5.html You can hid imei uid etc. All logs saved automatic at \LOG folder.. Regards, Chevli GCPROKEY |
@johnboy38 Hello Please use this new version with lot improvement and new future.. http://forum.gsmhosting.com/vbb/f922...msung-1896497/ Regards, Chevli GCPROKEY |
skeyXXXX? how do i get skey? is it given with MSL? thanks Quote:
Hello SKEY is device sign key number id. its bind to each device public key. its protection too same like imei cert is protection for imei repair. due to SKEY we can't use other device certs to other device. You can read via uart info with GCProKey most samsung devices. This come with imeicert too and best way to use for identify imei is for which model. We do not provide any imeicert,msl etc. we just provide way to use it. Regards, Chevli GCPROKEY |
i have just did a quick research and found out that. Skey identify the Model. so her a list for skey. SM-G900X SKEY=0478 SM-N910X SKEY=0772 SM-N915X SKEY=0208 X mean all letters related to that Model, for example N910T. |
i need help N910C with sim lock i choose reset efs via usb cable and the imei change to 350050500009692 No signal i can't write cert on it use cert from n910u i have backup 41002855447e91a1_35638706301**** how can i restore or write cert |
Using Version...1.0.0.0012 Selected Port VCP0 = COM16 Selected Model Samsung GSM Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := SM-N910C UNIQID := CR200A08FF27412 Default MSL found.. MSL Autho Pass.. Update IMEI Ok.. SKEY := 0065 QCOM(QUALCOMM) detected.. Checking imeicert... IMEISIGN PASS.. Update Simlock Ok.. Wifi_mac := C0BDD1BA5731 Wifi_mac update ok. Update SerialNumber ok.. Fixing FTM ok.. Repairing finish. !!! SUCCESS !!!! Total Time Take...00:00:53 Log Saved |
