10-06-2018, 15:46 | #1 (permalink) |
Junior Member Join Date: Sep 2018
Member: 2865960 Status: Offline Thanks Meter: 5 | SM J737P unlocking Support Required. Did any one try to unlock SM J737P sPRINT/BOOST VARIANT TO UNLOCK.. HELP WILL BE HIGHLY APPRICIATED. |
10-30-2018, 06:03 | #7 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2753460 Status: Offline Thanks Meter: 1 | I Currently have a J737P with Boost Mobile i flashed a Combination with odin and used Z3x to read info from it and now i want to move it back to Stock rom 8.0 but its failing with sw rev check fail device 3 binary 2 message i dont know if there is newer firmware or how to go back i even tried smart switch and its not supported can anyone please help |
10-30-2018, 06:12 | #8 (permalink) | |
Freak Poster Join Date: Jun 2016 Location: New ****** U.S.A
Member: 2590666 Status: Offline Thanks Meter: 130 | Quote:
Make sure firmware matches the binary the device has now, otherwise you’ll end up with same warning. (Might be helpful log or screenshot to check your binary) Go to phone settings-about phone and confirm firmware binary, the download and install latest firmware. Good luck and post results. Enviado desde mi iPhone utilizando Tapatalk | |
10-31-2018, 02:07 | #9 (permalink) | |
Member: 2753460 Status: Offline Thanks Meter: 1 | Quote:
i dont see binary... i just see model, android version,security patch level, baseband version, Kernel version, Build number, SELinkus status | |
10-31-2018, 02:31 | #10 (permalink) |
Member: 2590666 Status: Offline Thanks Meter: 130 | Take a look at this example: J737PVPU1ARED_SPT1ARED In this case U1 would be the binary. So far U2 and U1 are available for download. Last edited by yonic69; 10-31-2018 at 02:37. |
10-31-2018, 02:37 | #11 (permalink) |
Member: 2753460 Status: Offline Thanks Meter: 1 | i do see the combination file i put was a U2 binary and my original stock is U1... and im looking for firmware or stock ROM with U2 and i cant find, can anyone help? my current combination is COMBINATION_FAC_FA80_J737PVPU2ARI3 |
The Following User Says Thank You to jtands17 For This Useful Post: |
10-31-2018, 03:27 | #12 (permalink) |
Member: 2590666 Status: Offline Thanks Meter: 130 | Here is the file: J737PVPU2ARJ2_8.0_4File |
The Following User Says Thank You to yonic69 For This Useful Post: |
