Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 12-04-2015, 16:59   #1 (permalink)
Member: 1968939
Thanks Meter: 20
How to enable uart for G920V
I have a G920V and cert ready in hand. the *#0*# dialer code doesn't work for this device. So how can I write in uart if I can't enable the uart for this model???
Old 12-05-2015, 15:12   #2 (permalink)
Member: 2288583
Thanks Meter: 10
Enable diag g920v
Testing and working on 5.1.1
I enabled dm by ##366633#
Then plug phone into uart cable restart the phone,,, leave uart plugged in upon restart press *#0*# it should work
Old 12-31-2015, 17:52   #3 (permalink)
Crazy Poster
Member: 2280189
Thanks Meter: 10
I HAVE THE SAME PROBLEM
HERE IS YHE LOG
Using Version...1.0.0.0024
Selected Port VCP0 = COM4
Selected Model SM-G920V
Selected Task SAM MEID CERT WRITE
SAMSUNG MEID CERT WRITE STARTED...
Searching Phone Please wait...
Phone Not Found Retry Please.
Enter *#7284# select UART > PDA
Enter *#0808# select AP > MTP+ADB
MUST USE UART C3303K !!!RJ45 CABLE!!! ON ALL NEW SAMSUNG DEVICES.
DIAL *#0*# AND TRY AGAIN...
!!! Fail !!!!
Total Time Take...00:00:07
Log Saved
I TRIED 100000MILLON TIMES
Old 12-31-2015, 19:46   #4 (permalink)
Member: 2138290
Thanks Meter: 26
##dmmode# is the code
The Following 2 Users Say Thank You to sik528i For This Useful Post:
Old 01-01-2016, 20:24   #5 (permalink)
Crazy Poster
Member: 2280189
Thanks Meter: 10
Yes i did But The GCPROKEY BOX no detect any Galaxy s6 no Verizon no sprint no T-Mobile no att phone
Only detect Galaxy 5 down
Old 01-01-2016, 22:57   #6 (permalink)
zozodouce's Avatar
Member: 2273156
Thanks Meter: 80
Why don't you learn how
to use the dongle first.
Old 01-02-2016, 05:33   #7 (permalink)
Crazy Poster
Member: 2280189
Thanks Meter: 10
I don't have the dongle only the box with uart interface
The thing no work for nothing
Old 01-02-2016, 05:47   #8 (permalink)
zozodouce's Avatar
Member: 2273156
Thanks Meter: 80
it's the same, learn how to use it. Don't go around criticizing it, it works for me. I use it everyday.
Old 01-02-2016, 09:18   #9 (permalink)
Crazy Poster
Member: 1576036
put dial *#0*# and connect with cable uart c3300k 530k
Old 01-02-2016, 23:08   #10 (permalink)
Crazy Poster
Member: 2280189
Thanks Meter: 10
I have the original cable from Gc pro key
Old 01-06-2016, 06:43   #11 (permalink)
Member: 2425271
Thanks Meter: 4
Driver for uart connection also the problem please check the driver if its installed properly.
Old 06-20-2016, 16:59   #12 (permalink)
Member: 808967
Thanks Meter: 155
these keys releases or supports verizon bands used g900v
Page generated in 0.25292 seconds with 8 queries
