05-10-2017, 02:50 | #1 (permalink) |
Banned Join Date: Jan 2014 Location: Havana, Cuba Age: 40
Member: 2107306 Status: Offline Thanks Meter: 612 | HOW TO: Unlock S550TL [Debloating, rooting, unlocking] 1- OEM Unlock active, USB Debugging active. 2- Load boot.tar into odin and flash. 3- Install Debloater-setup-v3.90 and run it with the handset already connected. 4- Disable all packages related to "knox" and the next ones: com.samsung.klmsagent com.samsung.sdm sdmviewer.apk 5- Apply changes and run GCPRO 52 for unlock. The files are here: https://mega.nz/#!5ExjhTBJ!kDpIZ4K4g...r6DuMTev1ZdlM4 Hope it helps. PD: Unlocked in compilation S550TLUDU1APG1. Last edited by Prsctt; 05-10-2017 at 02:56. |
The Following 3 Users Say Thank You to Prsctt For This Useful Post: |
05-10-2017, 16:48 | #6 (permalink) |
Member: 2107306 Status: Offline Thanks Meter: 612 | Without root there you go: Using Version...1.0.0.0046 Selected Port ssudmdm0000 = COM12 Selected Model GT-I5500 Selected Task SAMSUNG Exynos Unlock SAMSUNG Exynos Unlock started... Searching phone... Phone Found Please Wait... Model := S550TL Ver := S550TLUDU1APG1/S550TLTFN1APG1/S550TLUDU1APG1/S550TLUDU1APG SN := RV8HB2**** IMEI := 359578071***** UNIQID := CQN00B976B857B TraceFone Detected.. Direct Unlock Success.. !!! Success !!!! Total Time Take...00:01:11 Log Saved |
The Following User Says Thank You to Prsctt For This Useful Post: |
05-10-2017, 20:25 | #7 (permalink) |
Freak Poster Join Date: Oct 2008 Location: dominican republic
Member: 874313 Status: Offline Sonork: polocell Thanks Meter: 37 | Using Version...1.0.0.0046 Selected Port ssudmdm0001 = COM36 Selected Model GT-I5503 Selected Task SAMSUNG Exynos Unlock SAMSUNG Exynos Unlock started... Searching phone... Phone Found Please Wait... Model := S550TL Ver := S550TLUDU1APG1/S550TLTFN1APG1/S550TLUDU1APG1/S550TLUDU1APG SN := RV8HB29XPJ IMEI := 35957807xxxx UNIQID := CQN00BA7CAADFB TraceFone Detected.. Direct Unlock Success.. !!! Success !!!! Total Time Take...00:01:13 Log Saved |
The Following User Says Thank You to polocell For This Useful Post: |
05-12-2017, 03:12 | #9 (permalink) | |
Freak Poster Join Date: May 2012 Location: Haiti, Port-Au-Prince, Carref.
Member: 1763284 Status: Offline Thanks Meter: 56 | Quote: Sent from my XT1254 using Tapatalk Last edited by Castle2k; 05-12-2017 at 03:29. | |
05-12-2017, 06:32 | #10 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @Castle2k Hello Only reason is bcs you are not using your gcpro to updat52. download update52 use it. old not gona donew supporting jobs. |
02-02-2018, 07:09 | #12 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2106315 Status: Offline Thanks Meter: 0 | SAMSUNG Exynos Unlock started... Searching phone... Phone Found Please Wait... Model := S550TL Ver := S550TLUDU1APG1/S550TLTFN1APG1/S550TLUDU1APG1/S550TLUDU1APG SN := RV8H8xxxxx IMEI := 359578070xxxxx UNIQID := CQN00D0859B856 ANDROID-ID = adb server version (32) doesn't match this client (39); killing... 4200d0859b8563e1_00003C85EE Type2 fail.. CHIP ID.. 03081000 Local scu-db update ok.. Reading nv_data please wait.. Fail to verify hmac... Unsupported baseband for code read... TraceFone Detected.. Direct Unlock Success.... !!! Success !!!! Total Time Take...00:03:26 Log Saved |
