08-18-2017, 07:50 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: jamaica
Member: 260210 Status: Offline Thanks Meter: 26 | imeicert write and bypass knox issue in new update 55 and 56 flashed combination file and try imeicert write BOTH UART and usb fail Using Version...1.0.0.0049 Selected Port ProlificSerial0 = COM83 Selected Model GT-I5500 Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Details. SM-G925F,N,FA50_G925FXXU5APK6,FA50_G925FXXU5APK6,G925 FX Model := SM-G925F UNIQID := 05157DF5B4B3050 Phone IMEI := 00000000000000 Device Knox Warranty is := Void Default MSL NO NEED RESET EFS... MSL autho fail...HczRDcAgCIThlUqjqI8KdY3bf4v+GvJdSLiw1RVITCy cGXhIw4eNQGJi3caQOzWjsjknp/PAl6yylbN5qE21kJP1ZpG98lTrqu0H !!! FAIL !!!! Total Time Take...00:00:18 Log Saved |
08-18-2017, 07:57 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @adnastar Hello Select imeicert write usb and select modem port write cert now and paste us log. Also issue is old known due to chinese PL2303 interface you are using. Use any FTDI box with c3303k cable should not have such issue. |
08-18-2017, 14:45 | #3 (permalink) |
Member: 260210 Status: Offline Thanks Meter: 26 | log using ftdi port c3303k uart cable Using Version...1.0.0.0049 Selected Port VCP0 = COM8 Selected Model GT-I5700 Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Details. SM-G925F,N,FA50_G925FXXU5APK6,FA50_G925FXXU5APK6,G925 FX Model := SM-G925F UNIQID := 05157DF5B4B3050 Phone IMEI := 00000000000000 Device Knox Warranty is := Void Default MSL NO NEED RESET EFS... MSL autho fail...HczRDcAgCIThlUqjqI8KdY3bf4v+GvJdSLiw1RVITCy cGXhIw4eNQGJi3caQOzWjsjknp/PAl6yylbN5qE21kJP1ZpG98lTrqu0H !!! FAIL !!!! Total Time Take...00:00:18 Log Saved log using modem port Using Version...1.0.0.0049 Selected Port ssudmdm1300 = COM107 Selected Model SM-G925T Selected Task SAM CERT WRITE USB ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := G925F VER := G925FXXU5APK6/FA50_G925FXXUX5APK6/G925FXXU5BPK2/FA50_G925FXXU5APK6 Phone IMEI := 00000000000000 Default MSL NO NEED RESET EFS... MSL autho fail...HczRDcAgCIThlUqjqI8KdY3bf4v+GvJdSLiw1RVITCy cGXhIw4eNQGJi3caQOzWjsjknp/PAl6yylbN5qE21kJP1ZpG98lTrqu0H !!! FAIL !!!! Total Time Take...00:00:59 Log Saved |
08-18-2017, 14:52 | #4 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @adnastar Hello Please contact me on skype i need to check this via team. Its always happens after bypass knox ? Do you know if you flash combination you don't need to use bypass knox ? |
08-25-2017, 01:30 | #6 (permalink) |
Freak Poster Join Date: May 2013
Member: 1946334 Status: Offline Thanks Meter: 17 | Using Version...1.0.0.0049 Selected Model SM-N920P Selected Task SAMSUNG Bypass Knox ADB Searching ADB device Please wait.. Device Detected... SELinux := Enforcing model:= SM-N920P Androids Version:= 6.0.1 Description Version:= nobleltespr-user 6.0.1 MMB29K N920PVPS3BPK1 release-keys Platform:= exynos5 [ samsungexynos7420 ] [ MDM9635M ] Baseband:= N920PVPS3BPK1 VER:= N920PVPS3BPK1/N920PSPT3BPK1/N920PVPS3BPK1/N920PVPS3BPK1 Carrier := SPR_USA Security Patch := 01-11-2016 Simstatus:= ABSENT ANDROID-ID = 05157df5a4f3d621_0000F4401C SU Version..2.79:SUPERSU Device is Secure Rooted..uid=0 System Permission is Read/Write... SAMSUNG Bypass Knox started... Please Wait while... Loader Ok Starting task... task fail...LUzbEcAgCFupYtD626JrZP8tGrgeHJcX2Qwa26QfetA 3cdMX0RLkPYQRnSNKt1yFQ9OiQr1UeRfxEihPZUkGp+L+d4iKP fW1BOEf !!! Fail !!!! Total Time Take...00:00:43 Log Saved |
08-25-2017, 09:17 | #7 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @DUMB-LUCK Hello Bypass knox only for exynos at present.. N920P is qcom flash combination use uart to write cert via MEID CERT WRITE. |
08-26-2017, 20:55 | #8 (permalink) |
Member: 1946334 Status: Offline Thanks Meter: 17 | Using Version...1.0.0.0049 Selected Port VCP0 = COM136 Selected Model SM-N920P Selected Task SAM MEID CERT WRITE SAMSUNG MEID CERT WRITE STARTED... Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := SM-N920P UNIQID := 05157DF5A4F3D62 Details. SM-N920P,N920P.04,N920PVPS3BPK1,N920PVPS3BPK1,N920PVP S3 Phone MEID := 99000700141486 Device Knox Warranty is := Void MSL found can continue.. Autho Pass.. SEED Passed.. Update MEID Ok.. MSL autho fail..Use Bypass Knox for such phones OR full flash combination (Engineering) firmware for such phone... IMEI Write fail..Use Bypass Knox for such phones OR full flash combination (Engineering) firmware for such phone...DBG fYzBDcAgDMRmghAOnlA6h/ffooS++qlOiaxEPsuYI0PCDr9bBSXU0U0qDDL1ok60AuK3kAck +5iTxqJvZbDdPe0kRaLJ/5ri0vH6AA== SKEY := 0092 QCOM(QUALCOMM) detected.. Checking meidsign... MEID SIGN FAIL Will retry.. Checking meidsign... MEID SIGN FAIL... CERT task fail still continue... Repairing finish. |
08-26-2017, 21:05 | #9 (permalink) |
Member: 1946334 Status: Offline Thanks Meter: 17 | flashed eng file. COMBINATION_FA51_N920PVPU3APJ1 Using Version...1.0.0.0049 Selected Port VCP0 = COM136 Selected Model SM-N920P Selected Task SAM MEID CERT WRITE SAMSUNG MEID CERT WRITE STARTED... Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := SM-N920P UNIQID := 05157DF5A4F3D62 Details. SM-N920P,N920P.04,FA51_N920PVPU3APJ1,FA51_N920PVPU3AP J1 Phone MEID := 99000696221503 Device Knox Warranty is := Void MSL found can continue.. Autho Pass.. SEED Passed.. Update MEID Ok.. MSL Autho Pass.. Update Match IMEI Ok.. SKEY := 0092 QCOM(QUALCOMM) detected.. Checking meidsign... MEID SIGN FAIL Will retry.. Checking meidsign... MEID SIGN FAIL... CERT task fail still continue... Repairing finish. !!! Fail !!!! |
08-29-2017, 20:18 | #11 (permalink) |
Member: 260210 Status: Offline Thanks Meter: 26 | PLEASE TEAM HURRY WITH NEW UPDATE LOSING MANY WORK hardly get any reply on skype Using Version...1.0.0.0049 Selected Model GT-I5503 Selected Task SAMSUNG SPRINT UNLOCK Searching ADB device Please wait.. Device Detected... SELinux := Enforcing model:= SM-J700P Androids Version:= 6.0.1 Description Version:= j7ltespr-user 6.0.1 MMB29M J700PVPU1APB7 release-keys Platform:= msm8916 [ qcom ] [ MSM8929 ] Baseband:= J700PVPU1APB7 VER:= J700PVPU1APB7/J700PSPT1APB7/J700PVPU1APB7/J700PVPU1APB7 Carrier := BST_USA AP UART Status := Disable. Security Patch := 01-02-2016 Simstatus:= ABSENT ANDROID-ID = d45c229e_00005A0777 Device is not rooted SAMSUNG ALL SPRINT UNLOCKING STARTED... Checking Data... Waiting for Loader... Loader Ok... dbg...RY5RDsUgCASvJFABv1t7jb3/LR6LTV5ijNkdB3whBHbBXtiGTdgNS4Z1fEAVNuDZ+duJkaybj/r4kC9G4vsVCbmhiOM+4oRO6ME3y55KRRmdpcW/SXIa7V+QDqP9XGMwn9jfHkJAnC01C+ZtQNQWNVfIFZLyAw== !!! Fail !!!! Restart Phone Manually if not done auto... Total Time Take...00:00:23 Log Saved |
08-31-2017, 09:28 | #12 (permalink) |
Freak Poster Join Date: May 2004 Location: Albania Age: 47
Member: 65765 Status: Offline Thanks Meter: 80 | Using Version...1.0.0.0049 Selected Port VCP0 = COM81 Selected Model SM-G925A Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Details. SM-G925A,N,FA50_G925AUCU6AQC1,FA50_G925AUCU6AQC1,G925 AU Model := SM-G925A UNIQID := 04157DF41D1CB93 Phone IMEI := 00000000000000 Device Knox Warranty is := Not Void Default MSL NO NEED RESET EFS... MSL autho fail...HczRDcAgCIThlUqjqI8KdY3bf4v+GvJdSLiw1RVITCy cGXhIw4eNQGJi3caQOzWjsjknp/PAl6yylbN5qE21kJP1ZpG98lTrqu0H !!! FAIL !!!! Total Time Take...00:00:21 Log Saved |
