07-17-2018, 13:45 | #1 (permalink) |
Insane Poster Join Date: Jul 2009
Member: 1072857 Status: Offline Thanks Meter: 4 | J727t1 network issu after unlok I need help to fix J727t1 bit1 weak 2g signal after unlock procedure with GCpro. Proc: Backup cet/ExynosEFS_Reset/write cert backup/SAMSUNG DRK FIX. Finally the device is unlocked but weak 2g 900mhz signal and serial number=none B.R. |
07-17-2018, 15:03 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @yako66 Hello Official way of J727T do not damage calibration.. way you used is not official. Sorry there is nothing to help you. Next time use credits and Tmobile unlock steps posted in http://forum.gsmhosting.com/vbb/f922...tions-1838017/ Buy credits from listed reseller http://forum.gsmhosting.com/vbb/f922...-list-2299732/ |
07-20-2018, 20:13 | #3 (permalink) | ||
No Life Poster Join Date: Jan 2018
Member: 2802156 Status: Offline Thanks Meter: 173 | Quote:
If still same issue, install shortcutmaker apk and find .radioinfo, and set to lte manually check carrier,sim if still same, redo unlock, wipe efs rewrite cert fix drk Quote:
09-17-2018, 00:24 | #5 (permalink) |
Junior Member Join Date: Apr 2018
Member: 2833240 Status: Offline Thanks Meter: 1 | I had the same issue. I guess that you flashed a j727t modem in bit 3 for make the process. After the unlock process you need to put again the original modem j727t1 and the signal problem will desappear |
