01-24-2016, 01:29 | #1 (permalink) |
Freak Poster Join Date: Oct 2015
Member: 2478873 Status: Offline Thanks Meter: 51 | SM-G920t1 unkwnon baseband Using Version...1.0.0.0024 Selected Model SM-G920T1 Selected Task READINFO ADB Searching ADB Devices... Device Detected... Security:= OFF Unsecure device model:= SM-G920T Androids Version:= 5.1.1 Description Version:= zerofltetmo-user 5.1.1 LMY47X G920TUVS3DOJC release-keys Platform:= exynos5 [ samsungexynos7420 ] [ unknown ] Warning Baseband is Unknown or damaged.... VER:= G920TUVS3DOJC/G920TTMB3DOJC/G920TUVS3DOJC Carrier := TMB_USA Simstatus:= NOT_READY BusyBox version := 1.23.2 IMEI-1 = null or empty ANDROID-ID = 04157df472b50216_0000FEAAEC Detected su binary at /xbin SU Version..2.49:SUPERSU Device is Secure Rooted..uid=0 System Permission is Read/Write... Total Time Take...00:00:33 here is the drk log Using Version...1.0.0.0024 Selected Port VCP0 = COM22 Selected Model SM-G920T1 Selected Task SAMSUNG DRK FIX Started Samsung DRK Fix... No reply on samsung mode.. DIAL *#0*# AND TRY AGAIN... !!! Fail !!!! Total Time Take...00:00:08 if someone could please help me getting baseband back...ive been trying with different boxes but seems I need special files or something |
01-24-2016, 06:38 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello Please connect phone in download mode & use ExynosEFS_Reset.. If still same you have hardware issue check in hardware. Please us latest update 31 |
The Following User Says Thank You to stanner_austin For This Useful Post: |
01-24-2016, 22:13 | #3 (permalink) |
Member: 2478873 Status: Offline Thanks Meter: 51 | thanks I reset efs and it was successful but I still cant find the phone on uart I hit read info uart and it never connects. it can be found through usb but nothing I try to do through uart. I am tried 2 cables one is r523k and the other is r150k = (C3300, C3303K) Using Version...1.0.0.0025 Selected Port ssudmdm0000 = COM5 Selected Model SM-G920T1 Selected Task SAMSUNG ExynosEFS RESET Searching phone... Device Found.. MODEL=SM-G920T1;UN=04157DF472B50216;CAPA=32;VENDOR=SAMSUNG; FWVER=0200;PRODUCT=KLUBG4G1BD-E0B1;PROV=PASS; Init ok.. Samsung Exynos EFS Reset Success.. !!! Success !!!! Restart Phone if not auto... Total Time Take...00:00:29 Using Version...1.0.0.0025 Selected Port VCP0 = COM22 Selected Model SM-G920T1 Selected Task SAMSUNG DRK FIX Started Samsung DRK Fix... No reply on samsung mode.. DIAL *#0*# AND TRY AGAIN... !!! Fail !!!! Total Time Take...00:00:07 any other suggestions will be welcome. |
01-25-2016, 06:10 | #4 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello Is device show now baseband ? imei is now showing 35000 ? If no then please check phone in hardware for baseband ic. if yes then please check if u dial code or not *#0*# and replug uart cable in phone and redo task u doing before. |
01-26-2016, 21:46 | #6 (permalink) |
Member: 2478873 Status: Offline Thanks Meter: 51 | thanks to everyone who replied....no still no baseband no imei at all.... ive been trying to fix this phone for a month..i tried 3 other boxes and I was hoping gcpro would fix it, but for some reason uart just wont connect , screen stays on all the time. I'm about to give up on this thing......can someone provide me with an eng sboot? that's the last thing ill try. |
01-27-2016, 04:38 | #7 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Sri Lanka@cellularsolutions
Member: 230004 Status: Offline Thanks Meter: 174 | why don't you check hardware.. I read your posts It must be a hardware issue. start from Rf section you"ll find an answer for sure, and by the way I'm afraid even if you try service commands after writing a sboot will not help you to solve this, |
02-24-2016, 20:03 | #8 (permalink) |
Junior Member Join Date: Dec 2015
Member: 2508986 Status: Offline Thanks Meter: 0 | I am experiencing the same problem with my SM-G920T. I have a GCpro Key (active) and ordered the FIDI addapter as well as both UART clips. Neither seems to work. When I try to run any program using the UART mode it fails. The program starts and indicates device detected, then after a few minutes fails indicating device not found. I also note that the DRK repair program says to dial *#7284# and set the phone to UART>PDA mode. This dialing sequence does not bring up any menu to set the phone. Another thing I see is that both UART clips have a slid switch to set what looks like a buffer size. How do I determine which setting is correct for my phone? When you say to check the hardware are you indicating the phone hardware as in disassemble and physically check it. If I dial *#0*# those tests all run fine with no errors. My IMEI is showing null and my baseband appears normal. Any suggestions before I just throw the phone in the incenerator? Report Post Edit/Delete Message |
