Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 01-24-2016, 01:29   #1 (permalink)
Member: 2478873
Thanks Meter: 51
SM-G920t1 unkwnon baseband
ive been trying to fix this phone. at the moment it has no baseband and ofcourse no IMEI I tried to do drk repair and I tried to wipe efs and uart never connects I'm not sure if its cause of the baseband. I already flashed latest software in phone through kies and I still don't get baseband. I also flashed nv from another phone along with efs and still nothing. has anybody been able to fix unknown baseband? here is the phone info.
Using Version...1.0.0.0024
Selected Model SM-G920T1
Selected Task READINFO ADB
Searching ADB Devices...
Device Detected...
Security:= OFF Unsecure device
model:= SM-G920T
Androids Version:= 5.1.1
Description Version:= zerofltetmo-user 5.1.1 LMY47X G920TUVS3DOJC release-keys
Platform:= exynos5 [ samsungexynos7420 ] [ unknown ]
Warning Baseband is Unknown or damaged....
VER:= G920TUVS3DOJC/G920TTMB3DOJC/G920TUVS3DOJC
Carrier := TMB_USA
Simstatus:= NOT_READY
BusyBox version := 1.23.2
IMEI-1 = null or empty
ANDROID-ID = 04157df472b50216_0000FEAAEC
Detected su binary at /xbin
SU Version..2.49:SUPERSU
Device is Secure Rooted..uid=0
System Permission is Read/Write...
Total Time Take...00:00:33
here is the drk log
Selected Port VCP0 = COM22
Selected Task SAMSUNG DRK FIX
Started Samsung DRK Fix...
No reply on samsung mode.. DIAL *#0*# AND TRY AGAIN...
!!! Fail !!!!
Total Time Take...00:00:08
if someone could please help me getting baseband back...ive been trying with different boxes but seems I need special files or something
Old 01-24-2016, 06:38   #2 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
Hello
Please connect phone in download mode & use ExynosEFS_Reset..
If still same you have hardware issue check in hardware.
Please us latest update 31
The Following User Says Thank You to stanner_austin For This Useful Post:
Old 01-24-2016, 22:13   #3 (permalink)
Member: 2478873
Thanks Meter: 51
thanks
I reset efs and it was successful but I still cant find the phone on uart I hit read info uart and it never connects. it can be found through usb but nothing I try to do through uart.
I am tried 2 cables one is r523k and the other is r150k = (C3300, C3303K)
Using Version...1.0.0.0025
Selected Port ssudmdm0000 = COM5
Selected Task SAMSUNG ExynosEFS RESET
Searching phone...
Device Found..
MODEL=SM-G920T1;UN=04157DF472B50216;CAPA=32;VENDOR=SAMSUNG; FWVER=0200;PRODUCT=KLUBG4G1BD-E0B1;PROV=PASS;
Init ok..
Samsung Exynos EFS Reset Success..
!!! Success !!!!
Restart Phone if not auto...
Total Time Take...00:00:29
!!! Fail !!!!
Total Time Take...00:00:07
any other suggestions will be welcome.
Old 01-25-2016, 06:10   #4 (permalink)
Member: 49752
Thanks Meter: 6,085
Hello
Is device show now baseband ? imei is now showing 35000 ?
If no then please check phone in hardware for baseband ic.
if yes then please check if u dial code or not *#0*# and replug uart cable in phone and redo task u doing before.
Old 01-26-2016, 04:27   #5 (permalink)
Member: 2437116
Thanks Meter: 26
make sure screen stays on through the whole process
Old 01-26-2016, 21:46   #6 (permalink)
Member: 2478873
Thanks Meter: 51
thanks to everyone who replied....no still no baseband no imei at all....
ive been trying to fix this phone for a month..i tried 3 other boxes and I was hoping gcpro would fix it, but for some reason uart just wont connect , screen stays on all the time.
I'm about to give up on this thing......can someone provide me with an eng sboot? that's the last thing ill try.
Old 01-27-2016, 04:38   #7 (permalink)
gayansuranga's Avatar
Member: 230004
Thanks Meter: 174
why don't you check hardware.. I read your posts It must be a hardware issue. start from Rf section you"ll find an answer for sure, and by the way I'm afraid even if you try service commands after writing a sboot will not help you to solve this,
Old 02-24-2016, 20:03   #8 (permalink)
Member: 2508986
I am experiencing the same problem with my SM-G920T. I have a GCpro Key (active) and ordered the FIDI addapter as well as both UART clips. Neither seems to work. When I try to run any program using the UART mode it fails. The program starts and indicates device detected, then after a few minutes fails indicating device not found. I also note that the DRK repair program says to dial *#7284# and set the phone to UART>PDA mode. This dialing sequence does not bring up any menu to set the phone. Another thing I see is that both UART clips have a slid switch to set what looks like a buffer size. How do I determine which setting is correct for my phone?
When you say to check the hardware are you indicating the phone hardware as in disassemble and physically check it. If I dial *#0*# those tests all run fine with no errors. My IMEI is showing null and my baseband appears normal.
Any suggestions before I just throw the phone in the incenerator?
Report Post Edit/Delete Message
Page generated in 0.22177 seconds with 8 queries
