03-22-2016, 09:13 | #16 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello Read basic help file in \updatexx\helpfiles folder N910V do not need any reset efs unless you have baseband unknown or boot loop issue. Use tape on BSI point of battery. Connect c3303k uart cable to any FTDI box you have and phone. gcprogsmtool select FTDI box port you pluged cable. select any model. Go to samsung select MEIDCERT Write press start and select any N910 cert. make sure phone screen is unlocked and keep alive. Once done check network, if issue follow same advice which given in this thread at post #7 |
03-22-2016, 21:13 | #17 (permalink) |
Insane Poster Join Date: Jul 2015
Member: 2425271 Status: Offline Thanks Meter: 4 | @Stanner Thanks You for your quickly respone it was easy to follow the instruction the only step I missed was leave the screen alive haha but I got it thanks Using Version...1.0.0.0027 Selected Port VCP0 = COM20 Selected Model Samsung CDMA Selected Task SAM MEID CERT WRITE SAMSUNG MEID CERT WRITE STARTED... Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := SM-N910V UNIQID := CR200FBD644C3B1 Phone MEID := 99000......... Device Knox Warranty is := Not Void MSL found can continue.. Autho Pass.. SEED Passed.. Update MEID Ok.. SKEY := 0772 QCOM(QUALCOMM) detected.. Checking meidsign... MEIDSIGN PASS.. Repairing finish... !!! Success !!!! Total Time Take...00:00:31 |
06-01-2016, 23:50 | #18 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | @stanner I go to my update39\helpfiles folder but I cannot find n910v file or folder also there is no option to select n910v in gcpro software, I am trying to get gsm signal on my 2 n910v, please help, tnx |
10-17-2016, 18:30 | #21 (permalink) |
No Life Poster Join Date: Mar 2005 Location: gsmwebstore
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | WHEN I TRY TO URT CABLE SHOW THIS Using Version...1.0.0.0039 Selected Port VCP0 = COM4 Selected Model GT-I5508 Selected Task SAM MEID CERT WRITE SAMSUNG MEID CERT WRITE STARTED... Searching Phone Please wait... Phone Not Found Retry Please. Enter *#7284# select UART > PDA Enter *#0808# select AP > MTP+ADB MUST USE UART C3303K !!!RJ45 CABLE!!! ON ALL NEW SAMSUNG DEVICES. DIAL *#0*# AND TRY AGAIN... !!! Fail !!!! Cert file used..F:\SAMSUNG\N\N910A\CERT\SM-N910A\SM-N910A\Cert-SM-N910A_355694060163020.cert Total Time Take...00:00:07 Log Saved |
