08-10-2016, 01:33 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: USA
Member: 945085 Status: Offline Thanks Meter: 70 | N920A write cert problems & solution here with GCPro I unlocked using z3x, then came back to gcpro and try to write imei using usb. It gave me an error saying I need to reset msl or reset efs. I ran exynos unlock on gcpro the 2nd time, and even though it detected it was unlocked already, it still performed the operation. I went back and did imei write with usb again and this time worked perfect! |
The Following User Says Thank You to toutanje For This Useful Post: |
08-10-2016, 08:04 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Your thread title is confusing. also please post logs while posting question. also at end you say all fine but people need logs screenshot to believe do you mind to share it? |
08-10-2016, 15:54 | #3 (permalink) |
Member: 945085 Status: Offline Thanks Meter: 70 | Using Version...1.0.0.0035 Selected Port ssudmdm0000 = COM14 Selected Model SM-N920A Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := N920A VER := N920AUCU2APB2/N920AATT2APB2/N920AUCU2APB2/N920AUCU2APB2 Phone IMEI := 353876072***** Default MSL NO NEED RESET EFS... MSL Autho Pass.. Update IMEI Ok.. SKEY := 0448 EXYNOS Type Detected.. Checking imeicert... IMEI-1 CERT PASS.. Fixing FTM ok.. Repairing finish. !!! SUCCESS !!!! Total Time Take...00:03:22 |
08-11-2016, 16:39 | #4 (permalink) |
Freak Poster Join Date: May 2015 Location: Los Angeles Age: 29
Member: 2400231 Status: Offline Thanks Meter: 124 | This has been mentioned countless times already. First use Exynos unlock to reset the MSL to a generic one. Then write cert through USB, no root. |
08-13-2016, 08:34 | #5 (permalink) | |
Member: 945085 Status: Offline Thanks Meter: 70 | Quote:
Yes... that is what I said the first time. All I was saying was I did exynos unlock first but with z3x and when I tried writing cert with gcpro it didnt work. The 2nd time, I did exynos unlock with gcpro instead then cert write worked. | |
08-16-2016, 18:58 | #6 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: Minneapolis MN USA
Member: 1815016 Status: Offline Thanks Meter: 77 | Quote:
Freshly flashed PB2, and still says to Reset MSL after doing Exynos Unlock. Knox is still intact | |
08-16-2016, 20:32 | #7 (permalink) |
Member: 945085 Status: Offline Thanks Meter: 70 | Keep trying Exynos unlock until it finally works when you write cert usb. I had a couple phones yesterday with the same problem. I must have done exynos unlock and write cert usb about 6 or 7 times until it finally worked. |
