08-04-2016, 16:58 | #1 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2236230 Status: Offline Thanks Meter: 2 | Need help bricked g925t 6.0.1 Wrote unikernel and new cert file. Did not make EFS backup. Customer reset device now I'm stuck with DRK error. When I try to use Fix DRK with GC Pro: Using Version...1.0.0.0035 Selected Port ssudmdm0000 = COM4 Selected Model SM-G925T Selected Task SAMSUNG DRK FIX Started Samsung DRK Fix... No reply on samsung mode.. DIAL *#0*# AND TRY AGAIN... !!! Fail !!!! Total Time Take...00:00:06 Log Saved Phone will not boot. Only to recovery. Device in Download mode above. I tried Odin but device is blocked by FRP. Try to remove FRP from GC Pro: Using Version...1.0.0.0035 Selected Port ssudmdm0000 = COM4 Selected Model SM-G925T Selected Task SAMSUNG FRP Remove Searching phone... Device Found.. MODEL=SM-G925T;UN=0715F7D183023238;CAPA=32;VENDOR=SAMSUNG;F WVER=0200;PRODUCT=KLUBG4G1BD-E0B1;PROV=FAIL; Init ok.. Fail-flash.. Possible New BootLoader Try Downgrade and retry... Finish... !!! Fail !!!! Restart Phone if not auto... Total Time Take...00:00:13 Log Saved |
08-04-2016, 17:25 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @kennyk99 Hello Did you made search or read sticky thread? http://forum.gsmhosting.com/vbb/f922...rokey-2073748/ Easy solution is find eng sboot posted by other user at forum flash it phone will start use drk repair and its done. |
08-05-2016, 12:20 | #4 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: Sudan
Member: 219803 Status: Offline Sonork: 1582317 Thanks Meter: 38 | Quote:
Sent from my SM-N920C using Tapatalk | |
08-05-2016, 12:46 | #6 (permalink) | |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @zozo2 Hello You are half right. Quote:
Eng firmware are samsung signed its accepted at any condition. @kennyk99 Hello If flashing eng sboot fail then you may flashing older try to find newer one to finish job. | |
The Following User Says Thank You to stanner_austin For This Useful Post: |
08-08-2016, 07:55 | #9 (permalink) | |
Banned Join Date: Jan 2014 Location: Havana, Cuba Age: 40
Member: 2107306 Status: Offline Thanks Meter: 612 | Quote:
https://drive.google.com/file/d/0BzX...w?pref=2&pli=1 Hope it helps. Last edited by Prsctt; 08-08-2016 at 08:01. | |
The Following User Says Thank You to Prsctt For This Useful Post: |
08-08-2016, 09:11 | #10 (permalink) |
Freak Poster Join Date: May 2010
Member: 1295465 Status: Offline Thanks Meter: 6 | sboot file 1st want to say thank u for the file, next before i flash something that i am not fully sure, is this the new eng sboot for the new 6.01 software on like pf1 that can not be donwgraded?? again thank u |
08-08-2016, 18:50 | #11 (permalink) | |
Give me just 30 mins to get to my home. I will flash pf1 then try to downgrade. See you later. | |
08-09-2016, 17:13 | #12 (permalink) |
Member: 2236230 Status: Offline Thanks Meter: 2 | doesnt look like the provided sboot will work for me since I'm already on 6.0.1 So I'm still stuck with Secure Download: Enabled, FRP Lock: On. Inability to flash a custom recovery. Phone only boots to recovery mode with error of DRK. DRK Repair option not working it fails. Any other suggestions? Get PIT for mapping Firmware update start SingleDownload sboot bin NAND Write Start!! Transmission Complete Now Writing Please wait about 2 minutes FAIL! Receive Response from boot-loader |
