12-05-2017, 03:05 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Canada
Member: 1211915 Status: Offline Sonork: 345634564 Thanks Meter: 93 | NOT POSSIBLE G930W8 REPAIR IMEI, WHY??? what problem GCKEY HAVE? I bought gcprokey new, I want to repair IMEI G930W8 Phone already rooted, gcprokey is not detecting phone when I make repair. Please check logs. what problem gckey have??? OR I MISS SOMETHING???? need solution for OLD PHONESSSSSSSSSSSSSSSSSSSSSSS -------------------------------------------------------- Using Version...1.0.0.0052 Selected Port ssudmdm0000 = COM18 Selected Model SM-G930W8 Selected Task SAM IMEI REPAIR ALL SAMSUNG IMEI STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE FAIL Make sure Phone is on UART PDA for newer OS.. No reply on samsung mode.. Enter *#7284# select UART > PDA Enter *#0808# select AP > MTP+ADB MUST USE UART C3303K !!!RJ45 CABLE!!! ON ALL NEW SAMSUNG DEVICES. DIAL *#0*# AND TRY AGAIN... Total Time Take...00:00:29 -------------------------- PATCH CERT NOT WORKING ALSO Selected Task SAMSUNG PATCH CERT Searching ADB device Please wait.. Device Detected... SELinux := Enforcing model:= SM-G930W8 Androids Version:= 6.0.1 Description Version:= heroltebmc-user 6.0.1 MMB29K G930W8VLU2APK3 release-keys Platform:= exynos5 [ samsungexynos8890 ] [ SHANNON335 ] Baseband:= G930W8VLU2API2 VER:= G930W8VLU2APK3/G930W8OYA2APK3/G930W8VLU2API2/G930W8VLU2APK3 Carrier := TLS_Canada Knox Warranty := Void AP UART Status := Disable. Security Patch := 01-11-2016 Network Mode := LTE Simstatus:= ABSENT ANDROID-ID = ce07160715a3a91a02_0000CA59F0 SU Version..2.82:SUPERSU Device is Secure Rooted..uid=0 System Permission is Read/Write... SAMSUNG PATCH CERT STARTED... Exynos Not Ready yet... Restarted phone... Total Time Take...00:00:01 --------------------------------------------------- PHONE ONLY READ INFO, NOT POSSIBLE REPAIR IMEI Using Version...1.0.0.0052 Selected Model SM-G930W8 Selected Task SAM Readinfo ADB Searching ADB Devices... Device Detected... SELinux := Enforcing model:= SM-G930W8 Androids Version:= 6.0.1 Description Version:= heroltebmc-user 6.0.1 MMB29K G930W8VLU2APK3 release-keys Platform:= exynos5 [ samsungexynos8890 ] [ SHANNON335 ] Baseband:= G930W8VLU2API2 VER:= G930W8VLU2APK3/G930W8OYA2APK3/G930W8VLU2API2/G930W8VLU2APK3 Carrier := TLS_Canada Knox Warranty := Void AP UART Status := Disable. Security Patch := 01-11-2016 Network Mode := LTE Simstatus:= ABSENT ANDROID-ID = ce07160715a3a91a02_00009FEAC5 SU Version..2.82:SUPERSU Device is Secure Rooted..uid=0 System Permission is Read/Write... Total Time Take...00:00:25 -------------------------------------------------- NEED SOLUTIONNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN -------------- UART ALSO NOT WORK ----- ------------------------- |
12-05-2017, 04:08 | #4 (permalink) | |
Member: 1211915 Status: Offline Sonork: 345634564 Thanks Meter: 93 | Quote:
i have used - CHIMERA TOOL CABLE --------------------------- - I used PROFILIC SERIAL CABLE. [IMG][/IMG] -------------------------------------- both are not detecting phone, what should i try now? Thanks | |
12-05-2017, 05:05 | #8 (permalink) |
Freak Poster Join Date: Jan 2015 Location: La Habana, Cuba
Member: 2324261 Status: Offline Thanks Meter: 117 | OMG !!! Not understand about UART and want to use GCPRO ... friend... go with the phone to a workshop with a real technician ... |
The Following User Says Thank You to armandogarriga For This Useful Post: |
12-05-2017, 05:49 | #10 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1331962 Status: Offline Thanks Meter: 3 | |
12-05-2017, 15:20 | #13 (permalink) |
Member: 2324261 Status: Offline Thanks Meter: 117 | If i dont know anything about cars i dont try to fix one because i will cause damage to something ... is the same for mobiles... If you dont know about something simple as UART, dont try to write a serial to a HWID CPID phone, you loose your phone for ever if something go wrong |
12-06-2017, 07:29 | #14 (permalink) |
Member: 1211915 Status: Offline Sonork: 345634564 Thanks Meter: 93 | I HAVE ALL CABLES UART Z3X BOX AND NSPRO BOX ----------------------------------------- I TRIED C3300K RJ45 CABLE AND PHONE NOT DETECTED ----------------------------------------- I TRIED Z3X BOX RJ45 CABLE AND PHONE NOT DETECTED ----------------------------------------- I TRIED bst dongle CABLE AND PHONE NOT DETECTED ----------------------------------------- I TRIED NSPRO RJ45 AND PHONE NOT DETECTED what is problem now?? - phone?? - cables??\ - gckey?? - Myself?? Thank you |
The Following User Says Thank You to christina_ For This Useful Post: |
12-06-2017, 07:46 | #15 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
ur picture alot cable not important because alot uart cable type i use 1 of gcpro work well u shoud ask ur reseller or try C3300k enjoy uart Gcpro | |
