Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 04-10-2015, 15:02   #1 (permalink)
Member: 540453
Thanks Meter: 75
G750a mega 2 imei write - worlds first again!
Using Version...1.0.0.0012
Selected Port VCP0 = COM10
Selected Model Samsung GSM
Selected Task SAM CERT WRITE
ALL SAMSUNG CERT WRITE STARTED..
Searching Phone Please wait...
Phone Found Wait...
TEST MODE OK..
Model := SM-G750A
UNIQID := ***************
Phone IMEI := ***************
Default MSL found..
MSL Autho Pass..
Update IMEI Ok..
SKEY := 0806
QCOM(QUALCOMM) detected..
Checking imeicert...
IMEISIGN PASS..
Update Simlock Ok..
Wifi_mac := 001236C33BAC
Wifi_mac update ok.
Update SerialNumber ok..
Fixing FTM ok..
Repairing finish.
!!! SUCCESS !!!!
Total Time Take...00:00:37
Log Saved
GCPRO KEY TEAM IS THE BEST!
The Following 2 Users Say Thank You to cbernardo For This Useful Post:
Old 04-10-2015, 15:23   #2 (permalink)
Member: 2185606
Thanks Meter: 30
World first in reset efs SONY base device from N910H,N910C history repeat again. We are first in world to provide G750A reset efs..
Thanks for your nice words.
also wanted to mention still other tool fail on most part of this..
imeicert write fail.due to much fancy softwares.
msl bypass error. due to bad solutions.
certificate not compatible errors. no experience to handle certificate writes.
GCPROKEY IS 100% solution for your all dally repair needs..
CERT WRITE WITHOUT ROOT TESTED.
Best Regards,
GCPro_Team
GCPROKEY
The Following 2 Users Say Thank You to GCPRO_HELP For This Useful Post:
Old 04-10-2015, 16:16   #3 (permalink)
Member: 232766
Thanks Meter: 22
yes but where to get cert files for these phones?
Old 04-10-2015, 20:11   #4 (permalink)
Member: 2140825
Thanks Meter: 5
Gcpro always keeping us ahead in the game, more to come
Old 04-13-2015, 21:40   #5 (permalink)
Member: 1295465
Thanks Meter: 6
any luck where to buy these certificates?
Old 04-14-2015, 09:00   #6 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@86vette07
You can check at those links.
http://forum.gsmhosting.com/vbb/f922...rokey-1930243/
http://forum.gsmhosting.com/vbb/f922...start-1818362/
also you can check at main sales section.
our solution is just use write imeicert same like factory. rest you have to manage due to illegal use of such solution we do not provide any certs.
Regards,
Old 08-12-2015, 18:39   #7 (permalink)
Member: 1810649
Sonork: GunShoot
Thanks Meter: 8
how you reset efs?????? for g750a ???
Old 08-14-2015, 03:02   #8 (permalink)
Gokuu2007's Avatar
Member: 712887
Sonork: gokuu2011
Thanks Meter: 349
@willensebastian
excuse g750a is sony based need reset efs and write cert.
Gokuu2007
Old 08-15-2015, 23:15   #9 (permalink)
Member: 2394513
Thanks Meter: 8
hi there i try to repair the imei of sam s5 sm-g900t1 and the key asks for this you can please explain me this
Phone Found Wait...
TEST MODE FAIL Make sure Phone is on UART PDA for newer OS..
No reply on samsung mode..
Enter *#7284# select UART > PDA
Enter *#0808# select AP > MTP+ADB
MUST USE UART C3303K !!!RJ45 CABLE!!! ON ALL NEW SAMSUNG DEVICES.
Total Time Take...00:00:26
Old 08-16-2015, 04:27   #10 (permalink)
Gokuu2007's Avatar
Member: 712887
Sonork: gokuu2011
Thanks Meter: 349
@w1n73rf3ll
you can read log , is clear, for write direct imei not supported, if you have certificate you write via uart cable c3300k some models need isolate bsi for this operation. first make option NEW Qualcom unlock.
Pd: in next time you can open other thread for this question.
Gokuu2007
Page generated in 0.18040 seconds with 8 queries
