08-25-2018, 20:06 | #2 (permalink) |
Freak Poster Join Date: May 2015 Location: Los Angeles Age: 29
Member: 2400231 Status: Offline Thanks Meter: 124 | Download the eng root kernel from support. Even though it says it's for G935T it will work for your device. Flash it using a modified Odin like prince comsy. Once device boots, open up GCPro and run Remove FRP ADB. After successful, try to setup device, should skip to the home screen. This is not necessary but I always do it, make a factory reset within settings. Once done just reflash stock firmware and done. |
The Following 2 Users Say Thank You to CloseCOder For This Useful Post: |
08-27-2018, 11:17 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @CloseCOder Hello Just to make it clear once u use RLOCK ADB or FRP REMOVE ADB with root you do not need to factory reset or bypass .. This options will REMOVE FRP/RLOCK fully . Reflash STOCK firmware is 100% recommended . |
