04-06-2019, 12:14 | #1 (permalink) |
Freak Poster Join Date: Oct 2017 Location: Portugal Age: 41
Member: 2771305 Status: Offline Thanks Meter: 59 | V350AWM IMEI Repair | V1.0.0.0064(unsupported new lg) it looks that the software hangs... can't tell! could you help? Code: Using Version...1.0.0.0064 Selected Port LGE Mobile USB Serial Port COM10 Selected Model LG Android Selected Task GCMod_Method Searching phone... Build...MPSS.AT.4.0.c2.9-00045-SDM845_GEN_PACK-1.166851.3.169593.2 Device Detected... SELinux := Enforcing model:= LM-V350 Android Version:= 8.0.0 Description Version:= judyp_lao_com-userdebug 8.0.0 OPR1.170623.032 1827723393dd6.FGN test-keys Platform:= sdm845 [ judyp ] [ ] Baseband:= MPSS.AT.4.0.c2.9-00045-SDM845_GEN_PACK-1.166851.3.169593.2 Factory Ver := LMV350AT-00-V11i-LAO-COM-OCT-04-2018-ARB00+0 Model & Firmware Ver := V350AWM11i Security Patch := 01-09-2018 ABI:= arm64-v8a SDK Ver:= 26 Network Mode := LTE Simstatus:= ABSENT BusyBox version := 1.16.2 ANDROID-ID = LMV350AWM6541361b_0000EEBA56 SU Version..18.1:MAGISKSU ( Device is Secure Rooted..uid=0 Starting All QCOM IMEI Repair... Please wait till finish... Build...MPSS.AT.4.0.c2.9-00045-SDM845_GEN_PACK-1.166851.3.169593.2 Damaged IMEI & Security.. IMEI-1 := 000000000000000 Damaged IMEI & Security.. Repaired IMEI-1 := 000000000000000 job done.. !!! SUCCESS !!! Please wait till finish... Backup QCN..C:\GCPro_Team\Backup\QCN\LM-V350_MPSS.AT.4.0.c2.9-00045-SDM845_GEN_PACK-1.166851.3.169593.2_LMV350AW_06_04_2019_12_08_36_PM_.qcn Total Time Take...00:00:34 Log Saved |
04-06-2019, 12:22 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @b8engl Hello Log do not show where its hang. For that we may need to check via team viewer. Second your pc have backup of security and qcn both. Now if your imei is zero you must use nv method and repair imei. then write qcn. |
04-06-2019, 12:56 | #3 (permalink) |
Member: 2771305 Status: Offline Thanks Meter: 59 | thanks stanner_austin for the quick reply! I can only see the QCN file at C:\GCPro_Team\Backup, doesn't existe SEC folder. I have MEID 00000000, but if I do factory reset will be 0-05 So, your sugestion is that I do the steps: - GCMod_Method; - NV_Method; - Write QCN. |
04-06-2019, 13:36 | #4 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @b8engl Hello Backup QCN..C:\GCPro_Team\Backup\QCN\LM-V350_MPSS.AT.4.0.c2.9-00045-SDM845_GEN_PACK-1.166851.3.169593.2_LMV350AW_06_04_2019_12_08_36_P M_.qcn If your imei is ok and meid is empty just Enter MEID most case meid is just 14 digit of imei. so enter it and use nv method to repair. If you have network issue write qcn after you repair imei or meid. Do not factory reset phone backup of original security is saved in phone not in pc. if you format it will be lost. |
04-06-2019, 13:48 | #5 (permalink) | |
Member: 2771305 Status: Offline Thanks Meter: 59 | Quote:
Ok, so no factory reset after flash firmware! If I do will restore original security ( IMEI 0-05 ). If I flash firmware I read MEID 00000000 with *#06# I don't have IMEI or MEID, what to do? If I choose GCMod_Method the software hangs, so if I choose the steps above and write QCN, that will be empty write? I don't get it.... | |
