08-18-2015, 06:14 | #1 (permalink) |
Insane Poster Join Date: Dec 2007 Location: Colombia
Member: 652344 Status: Offline Sonork: 100.1607965 Thanks Meter: 5 | Samsung S6 G920i Stuck In Samsung Logo This is my problem: I have a S6 SM-G920I in 5.1.1, it was reactivation lock. I did bypass, I tried root but not was possible. I can write cert without root, first I did reset EFS with BST Dongle, after I write cert with GC Pro Key, and all ok, working full LTE. But, after I make a hard reset vía recovery and now the phone stuck in logo "Samsung Galaxy S6" I tested these methods but still have the problem. * Tried downgrade to 5.0.2 but not was possible. * Reflash with 5.1.1 (Trinidad and Tobago, Argentina, Nepal) * Flash S6-UniKernel_v6-0001-ODIN.tar and/or S6-UniBase_BOG8_v2.tar, nothing (Error with Odin) * Write this recovery "twrp-2.8.7.1-zeroflte.img.tar", (Error odin) * Reset again EFS with BST Dongle in Download mode. * Flash modem and boot G920I-DVU2COF8-BOOTLOADER.tar.md5 and G920I-DVU2COF8-MODEM.tar.md5... ( * Flash with Indian firmware, without Hidden.img. * Flash with any Firmware 5.1.1 + Pit ZEROFLTE_AUS_XSA.pit But nothing, the problem continues. I want try, write EFS in download mode, but I haven't backup, I don't know if is possible. Someone have any idea? Sorry for my english |
08-18-2015, 09:29 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @REDKOF Hello problem 1 is reactivation problem 2 is device root key if you have any imeicert with DRK u can write with gcpro to fix this issue.. but that imeicert should be for s6 G920I and must with DRK data. never reset phone in boot mode unless there are all other option closed.. or team said so.. reset with bst is your big mistake. @muntazim2 Read section name before reply some one..this is not octo section. |
The Following 4 Users Say Thank You to stanner_austin For This Useful Post: |
08-18-2015, 15:24 | #4 (permalink) |
Member: 652344 Status: Offline Sonork: 100.1607965 Thanks Meter: 5 | @stanner_austin Thanks for support. How I to know when a cert have DRK data? I have certs read with other box. Br I tried, but first "reactivation lock" do not allow to write custom firmware, (I know that is official firmware, but when convert with octopus, this change) and show me "Custom Binary(BOOT) Blocked by R/L." |
10-14-2015, 11:49 | #6 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @treo29 Hello 100% factory repair only via DRK certificate write. There are other temp way to fix .. Flash any custom KERNEL which skip device protection. that will let phone work for sure. Latest example is UniKernel. |
The Following User Says Thank You to stanner_austin For This Useful Post: |
10-14-2015, 15:03 | #7 (permalink) | |
No Life Poster Join Date: May 2006 Location: wordwide Age: 48
Member: 279394 Status: Offline Sonork: 1591760 Thanks Meter: 105 | Quote:
Br Treo29 | |
10-20-2015, 07:23 | #8 (permalink) |
Member: 652344 Status: Offline Sonork: 100.1607965 Thanks Meter: 5 | I think that write a Unikernel is not possible, because the bootloader is locked and the reactivation lock status is ON. I hope find a solution for this. Help us Stanner please. |
10-20-2015, 10:03 | #9 (permalink) | |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Quote:
Here is solution. http://forum.gsmhosting.com/vbb/f922...-edge-2003333/ As usal gcpro come up with world first and exclusive for all users. if you have DRK Damaged S6,S6EDGE,S6PLUS,NOTE5 in hand you can contact us via messengers. | |
