Samsung SM-N910A Note 4 Done Sucessfully. 1. Wipe EFS Without ROOT ( Credit goes to jusmejose for this method ) Here is the method to wipe the EFS without Root. i. Open dialer and dial *#9090# ii. Press Menu Enter Q iii. Press Menu and hit Back, After Enter Key 0000 Wait for couple of seconds. You will be Prompted into MAIN MENU iv. Select UE SETTINGS & INFO, SYSTEM, NV BACKUP TEST, ERASE ALL EFS1/2/3 and Select YES. v. EFS WIPE is done without ROOT. ***Warning!!! I'm not responsible for anything that happens to your Device*** 2. Write IMEICERT to your phone. (NB. Use UART Cable and remember battery trick.) 3. All is DONE , Phone is UNLOCKED Also remember to back up QCN. QCN Backup Quote:
Write IMEICERT Quote:
Regards , Mediaextensi:)ns. |
But which box you use for write cert? As you said you use the uart cable. Tanks |
Hello You can use any FTDI interface you have. if you don't have then you can buy one from gpg with cable set too. Regards Chevli GCPROKEY |
did you had signal issues ? can you share the QCN file ? |
Can you share this qcn or cer N910A ? |
Does this changes imei? |
how did u root n910a ? |
Thank you for the credit ... I didn't wanted to release this stuff but I seen a lot people breaking their heads trying to wipe the EFS ... I also have another method with Odin just incase if the "Hidden Menu" gets patched by Samsung OTA |
Here is a clean QCN N910A I you guys need it .. SM-N910A_MPSS.DI.3.0.c5-00300-M9625TAARANAZM-1.7892.2_26-1-2015_20-30-29 |
@JUSMEJOSE whats the right way to write this QCN ? do I have to wipe efs then write qcn then cert ? or just directly ? any help ? thanks |
Or back your own QCN before you wipe "EFS" using "QPST,z3x,Octopus" or any dongle/Box that supports "QCN" BackUP/Restore .... |
