Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 04-13-2017, 20:48   #1 (permalink)
Member: 2325887
Thanks Meter: 134
Thumbs up after write cert by z3x and octopus imei 00 can gcpro fix ?
after write cert by box z3x and ocopus box my samsung model g920f
insert sim card and not registered on network
gcpro key can be repair this problem?
first problem imei 3500000000000
Old 04-13-2017, 20:53   #2 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 713
Yes if you have gc pro you can.. Assuming you are on higher and latest build you need combination firmware..install it and after that you can write cert by uart(comport)..
Notebypass knox or reset msl is still required to write cert)
Old 04-13-2017, 21:01   #3 (permalink)
Member: 2325887
Thanks Meter: 134
combination firmware WHAT THIS?
g920fimei 359937068039505
Old 04-13-2017, 23:07   #4 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
Red face bro
its factory firmware for fix phone bro.
Old 04-14-2017, 00:51   #5 (permalink)
Member: 2529251
Thanks Meter: 275
No bro . First you need to root the device and use gcpro key yo bypass knox then write the cert back. Check to see if the baseband is good if not you need efs and cert
Sent from my SM-G930F using Tapatalk
Old 04-14-2017, 00:52   #6 (permalink)
Member: 2529251
Thanks Meter: 275
PM me if you need help
Old 04-14-2017, 05:15   #7 (permalink)
Member: 2325887
Thanks Meter: 134
plz upload here efs file thanks
Old 04-18-2017, 16:34   #8 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 713
Root can damage knox Mr.Pro. What I said is based on my personal experience. If you have never tried it out it does't mean that it will not work.
Page generated in 0.15667 seconds with 8 queries
