Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 02-10-2017, 00:34   #1 (permalink)
Member: 2598737
Thanks Meter: 4
Angry SM-G930P FRP Failed Part 2
Here is the log:
Using Version...1.0.0.0041
Selected Port ssudmdm0001 = COM12
Selected Model SM-G930P
Selected Task SAMSUNG FRP Remove
Searching phone...
Device Found..
MODEL=SM-G930P;UN=CE011601A903C63C03;CAPA=32;VENDOR=SAMSUNG ;FWVER=0003;PRODUCT=KLUBG4G1CE-B0B1;PROV=PASS;
Init ok..
FRP Removed.
!!! Success !!!!
Restart Phone if not auto...
Total Time Take...00:00:14
1. It did not remove the FRP.
2. Tested on 3 different firmware version, unfortunately it's impossible to downgrade to very old firmwares.
3. I tried remove FRP(ADB Method) which also does not work
4. ADB Enable, does not work.
5. Flashing unsecure boot image which is used for rooting, does not help. This also causes device to bootloop.
Old 02-10-2017, 08:47   #2 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@dorin1993
Hello
I have already reply you on one of thread.
If unsecure root for G930T do not provide you adb and root then sorry we do not have any other solution.
99% you did not check for ADB just worry for phone not starting.. did you really check in pc with frp remove adb option after flashing G930T root kernel from support ?
Page generated in 0.10991 seconds with 8 queries
