12-14-2015, 23:26 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | ******sm-n920a imei repair * drk fix********* Selected Port VCP0 = COM27 Selected Model SM-N920T Selected Task SM-N920A ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := SM-N920A UNIQID := 05157DF551F3EF1 Details. SM-N920A,N,N920AUCU1AOGG,N920AUCU1AOGG,N920AUCU1AOGG, N, Phone IMEI := 00000000000000 Default MSL NO NEED RESET EFS... MSL Autho Pass.. Update IMEI Ok.. SKEY := 0448 EXYNOS Type Detected.. Checking imeicert... IMEI-1 CERT PASS.. Update Simlock Ok.. Wifi_mac := EC1F72B18398 Wifi_mac update ok. Update SerialNumber ok.. Fixing FTM ok.. Repairing finish. !!! SUCCESS !!!! Total Time Take...00:02:11 Log Saved Using Version...1.0.0.0023 Selected Port VCP0 = COM27 Selected Model SM-N920T Selected Task SAMSUNG DRK FIX Started Samsung DRK Fix... Phone Found Please Wait... Details. SM-N920A,N,N920AUCU1AOGG,N920AUCU1AOGG,N920AUCU1AOGG, N, Model := SM-N920A UNIQID := 05157DF551F3EF1 Phone IMEI := XXXXXXXXX Phone MEID := XXXXXXXXXXXX Default MSL NO NEED RESET EFS... ROOTKEY IS NOW GOOD.. !!! Success !!!! Total Time Take...00:00:17 Log Saved |
12-15-2015, 06:03 | #2 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: NYC
Member: 1105429 Status: Offline Thanks Meter: 118 | Quote:
can you share what steps you took? for example did you have to flash eng sboot before you write cert? did you wipe efs first? if you an list the steps you did beside Write cert and DRK DRK repair. Thank you | |
12-15-2015, 07:26 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello DRK Repair do not need any kind or wipe efs. do not need msl default. do not need anything special just uart mode and use DRK Repair. |
The Following User Says Thank You to stanner_austin For This Useful Post: |
12-15-2015, 07:30 | #5 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello eng sboot usefull on many case. like att phone have boot locked cant write custom kernel to get normal mode. like msl kernel security error on imeicert write. |
12-15-2015, 14:54 | #6 (permalink) | |
I did 2 phones in the last 2 days, both got stuck at the samsung logo. both for G928A and N920A this is what i did: wipe EFS, phone reboot Write Cert --> sucess DRK Repair -->sucess, it says key is now good Reboot.. phone got stuck on logo. Flashed eng sboot. --->phone boot up. DRK Repair ---> sucess, it says keys is already good Reboot.----> stuck in logo... after that.. nothing i do will boot up.. reflash stock firmware, flash sboot again and again.. only way to fix both phones was flash Factory binary, repair DRK 1 more time. re-flash stock, and then it's good.. is there a specific step that MUST be followed to avoid this stuck at logo problem? any feedback would be appreciated, and I"m sure other users could use this info so they do not get into the same problem I did. | |
12-15-2015, 17:52 | #7 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @hyratech Hello Not always stuck on samsung logo is drk issue.. You should check in recovery if any error there. Also its depend on how you made wipe.. some efs wipe do not let it work correct. After drk repair make sure format phone if you do not format via recovery or format button you may have this issue. |
12-15-2015, 18:08 | #8 (permalink) | |
Member: 1475064 Status: Offline Thanks Meter: 347 | Sounds like your efs wipe file is the culprit... Quote:
01-13-2016, 22:46 | #9 (permalink) | |
Freak Poster Join Date: Aug 2015
Member: 2447871 Status: Offline Thanks Meter: 3 | Quote:
someone told me to fix DRK but if i connect my phone via uart the software asks me to dial *#0*# i do it but theres no menu on my phone | |
01-14-2016, 17:32 | #11 (permalink) |
Registered User Join Date: May 2006
Member: 274461 Status: Offline Thanks Meter: 17 | @stanner_austin I bought your box recently to repair DRK for a S6, g920i and a S6 edge, g925T both phones hae DRK fixed but when i try to write cert, imei file it say that it has custom kernel error, and need eng sboot for both phones, where can i get this file? Both phones can turn on but imei is 35********* |
01-16-2016, 16:54 | #12 (permalink) | |
You need to use eng sboot in order to write certs of your phone has been rooted... Sent from my iPhone using Tapatalk | |
01-23-2016, 17:42 | #14 (permalink) |
Junior Member Join Date: Jul 2015 Location: United States
Member: 2419703 Status: Offline Sonork: jawad Thanks Meter: 0 | imei repair n920A Can you please show step by step on imei repair on n920a. Because the box does not recognized the phone when is plug to urat cable. Any help with that please. Thank you |
01-24-2016, 01:37 | #15 (permalink) |
Freak Poster Join Date: Sep 2015 Location: HERE
Member: 2457641 Status: Offline Thanks Meter: 153 | u need to fix uart drivers. make sure they are installed properly and dial *#0*# then connect uart cable and perform operation. hit the thanks button if this helped you. |
