Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 08-13-2016, 19:56   #1 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
Angry write cert SM-G925F Fail why ?
Phone Found Wait...
TEST MODE OK..
Model := G925F
VER := G925FXXS4DPG2/G925FOXA3DPDP/G925FXXS4DPG1/G925FXXS4DPG2
Phone IMEI := 00000000000000
Default MSL NO NEED RESET EFS...
MSL autho fail CustomKernal Error use ENG SBOOT OR ENG KERNEL..
!!! FAIL !!!!
Total Time Take...00:00:43
Log Saved
i need file if any people suppport files if possible
Old 08-13-2016, 22:43   #2 (permalink)
ramsey1976's Avatar
Member: 581848
Thanks Meter: 119
I have same problem with G925i uptill now team has not responded
May be stanner austin is not around to attend to this
Old 08-14-2016, 07:59   #3 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
Hello
Solution is in log and posted thousand of time same answer.
If you still cant get it then sorry i can't help more on this.
Old 08-14-2016, 10:10   #4 (permalink)
ramsey1976's Avatar
Member: 581848
Thanks Meter: 119
@ stanner Austin .....please I couldn't get any answer from the search I made on the support forum
I think may be theirs something I may be getting wrong please help me with the link once more please.....
Sent from my iPad using Tapatalk
Old 08-14-2016, 10:59   #5 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
i have done to day write g925F lates build with knox tricp no need engroot or engsboot yet
Old 08-14-2016, 18:33   #6 (permalink)
Member: 1381685
Sonork: 100.1668719
Thanks Meter: 81
Check Your imei is 35000000000000 If It IS
In each case if the nvdata damaged the imei will be same like that
Or Try To downgrade Modem But At Your Own Risk
Old 08-14-2016, 21:13   #7 (permalink)
Crazy Poster
Member: 1971921
Thanks Meter: 24
Smile
Originally Posted by ghacks View Post
Phone Found Wait...
TEST MODE OK..
Model := G925F
!!! FAIL !!!!
Log Saved
Hello You Need Wait It is New Securty I mean Firmwares Jule So Security Patch Lever 1 Jule Can not be done With Any Tool Need First Flash Phone With LastesT combination File First Try Find It At Moment At this Time No more way And Dont worry Gcpro key Team Will add Support Lastest Firmware As soos As will Possibel TeaM Works So Keep Phone Or Back To *******r Need wait Thank You
Old 08-14-2016, 21:15   #8 (permalink)
Crazy Poster
Member: 1971921
Thanks Meter: 24
Yes You are True Need try Downgrade but if phones flashed Jule Firmware You can not it downgrade with any way Not Possibel Brother Thanks
Old 08-14-2016, 21:17   #9 (permalink)
Crazy Poster
Member: 1971921
Thanks Meter: 24
Yes if knoc not tricp it is Possible Wit GreaT Tool Gcpro Thank You Brother
Page generated in 0.17919 seconds with 8 queries
