09-30-2016, 21:48 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: United States
Member: 2146046 Status: Offline Thanks Meter: 62 | IS there anyway to repair IMEI 350000000000006 without backups? G920 (solve) This may be dumb question but is there any way to repair IMEI 35000000000006 on a G920T without any Cert backups or NV backups? IF there is a solution to fix this IMEI can anyone please share? Why does this happen? Thanks! |
10-01-2016, 01:58 | #5 (permalink) | |
Freak Poster Join Date: Feb 2014 Location: INA
Member: 2130017 Status: Offline Thanks Meter: 43 | Quote:
1. read info uart 2. bypass knok adb 3. imecert write usb with any backup cert from sam model 4. to repair sn default phone do this AT+SERIALNO=2,11digitSN in at terminal and press send at 5. done hope usefull. thx | |
The Following 5 Users Say Thank You to izzicruise For This Useful Post: |
10-01-2016, 13:28 | #6 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @GTrader Hello go to updatexx\helpfiles\How to repair exynos imeicert write gcpro.txt read it. must write imei cert to repair imei on most samsungs. |
The Following User Says Thank You to stanner_austin For This Useful Post: |
10-02-2016, 13:19 | #8 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NYC/USA
Member: 1283129 Status: Offline Thanks Meter: 135 | It isn't a dumb question. But there is no 10000% solution. I have some G925F/G925I with the same problem. 35000000003. Can't write cert no matter what with this or any other tool. Phone behaves normally. I see many other people with the same problem. How to tell if baseband IC is really damaged? |
10-02-2016, 14:25 | #9 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello If you see your phone imei as 3500000 this means your phone baseband is fine. Try to read helpfile and follow steps mention in it. We can not post each new user same thing which posted thousands time and tested too with thousands of users. YOU ARE WRONG ABOUT NO SOLUTION, GCPRO IS 1000% & ONLY SOLUTION FOR MOST EXYNOS. |
The Following 2 Users Say Thank You to stanner_austin For This Useful Post: |
10-03-2016, 15:31 | #10 (permalink) |
Member: 2146046 Status: Offline Thanks Meter: 62 | Ok, So I was able to write a random CERT file and it worked 100% BUT...is there any way to restore the phones ORIGINAL IMEI without an ORIGINAL CERT backup?? |
10-03-2016, 16:41 | #11 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @GTrader Hello Please post log of successful cert write. so other user can see who clam that no 100% solution bla bla. You can write original imei u won't get network unless you write original imei cert or nv_data.bin . There is no other option at present. |
10-03-2016, 20:05 | #12 (permalink) |
Member: 2146046 Status: Offline Thanks Meter: 62 | 100% Working CERT WRITE. Network is working 100%. NEED TO DO BYPASS KNOX BEFORE WRITING CERT! Using Version...1.0.0.0039 Selected Port VCP0 = COM34 Selected Model SM-G920T Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... Model := SM-G920T UNIQID := 03157DF32B47B30 Phone IMEI := 00000000000000 Default MSL NO NEED RESET EFS... MSL Autho Pass.. Unknown reply0 DBG.. MTFfMTZfNTlfNDJfNDNfNDJfNTZfMkFfMjhfNUNfMjNfMkVfND lfMzdfMjlfMjZfNTRfNTVfNTdfNUFfNTJfNDlfNUVfNDhfMzBf NEZfNUFfMjc= Update IMEI Ok.. SKEY := 0346 QCOM(QUALCOMM) detected.. Checking imeisign... IMEI-1 SIGN FAIL Will retry.. Checking imeisign... IMEI-1 SIGN PASS.. Update Simlock Rejected.. Fixing FTM ok.. Repairing finish. !!! SUCCESS !!!! Total Time Take...00:03:11 |
The Following 3 Users Say Thank You to GTrader For This Useful Post: |
