08-07-2016, 07:22 | #1 (permalink) |
Freak Poster Join Date: Jan 2012 Location: india
Member: 1714295 Status: Offline Sonork: muntaziim Thanks Meter: 59 | Xiaomi Redmi Note 3 imei repair Done by Gcprokey Selected Port QCUSB_COM341_1 = COM341 Selected Model GT-I5503 Selected Task GCMod_Method Searching phone... Build...MPSS.TA.2.0.c1.1-00022-8976_GEN_PACK-1.60150.2.63218.1 Device Detected... model:= Redmi Note 3 Androids Version:= 5.1.1 Description Version:= kenzo-user 5.1.1 LMY47V 6.8.4 release-keys Platform:= msm8952 [ qcom ] [ msm ] Baseband:= -8976_GEN_PACK-1.60150.2.63218.1 Simstatus:= ABSENT,ABSENT BusyBox version := 1.20.2 ANDROID-ID = d4d41861_0000F70A18 Detected su binary at /xbin SU Version..2.74:SUPERSU Device is Secure Rooted..uid=0 System Permission is Read/Write... Starting All QCOM IMEI Repair... job done.. !!! SUCCESS !!! Total Time Take...00:00:14 Log Saved |
The Following 3 Users Say Thank You to muntazim2 For This Useful Post: |
08-18-2016, 09:31 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @pr1mux Hello Process is same as other qcom models. enable diag if you can do this via code or any other way you can skip rooting. if you can't find code or other methods use root press enable diag. check device manager if need install drivers. Use gcpro gsmtool scan port and select diag port. Select any model from list. Enter imei and try all method in list one by one. Once success on each method power off and power on phone and check if imei is repaired or not. |
07-26-2017, 07:43 | #6 (permalink) |
Freak Poster Join Date: Dec 2016
Member: 2666708 Status: Offline Thanks Meter: 62 | -need normal working qcn -change in qcn file meid/imei like in your phone -erase modemst1/modemst2 via root -restore qcn via QPST |
The Following User Says Thank You to MFKilla For This Useful Post: |
07-27-2017, 09:57 | #10 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @pr1mux Hello By default GCPro QCN Write will skip imei. If your imei is already 00 use NV Method to write imeis. Once its done restore QCN if not already done. |
