12-14-2021, 05:08 | #1 (permalink) |
Product Supporter Join Date: Feb 2013 Location: UAE
Member: 1881342 Status: Offline Sonork: NA Thanks Meter: 398 | UMT Box/Dongle Activation/Credit UMT Box/Dongle Activation/Credit Supported functions: - Read Info - Reset FRP (For devices supporting this feature) - Reset Locks (All Android Versions, Encrypted Userdata NOT Supported) - Read Pattern (Android 5.x and earlier, Encrypted Userdata NOT Supported) - Format FS - Format FS (Advance) - IMEI Repair in META / Boot Mode - Backup NVRAM - Restore NVRAM - Reboot to META / FACTORY / FASTBOOT Mode - Added Support for Helio CPU (MT6750, MT6755, MT6763, MT6739 etc) - Disable Lock / Restore Lock for Encrypted Userdata - Remove Locks for Encrypted Userdata for Vivo - Factory Reset in META Mode (Vivo, Oppo and others) - SafeFormat Option to let device format itself safely in recovery - Added Support for Helio X20 (MT6797) - Oppo/Realme Safe Factory Reset in META Mode - Added Disable Auth to disable SLA/DAA - Added Mi Account Reset - Xiaomi IMEI Repair - NVRAM/NVDATA Format - META Reboot for SLA Enabled Devices - MTK One Click Function Added - Crash Preloader Added - Added More Options in MTK One Click - Added Bootloader Unlock / Relock - Added RPMB Read/Write - Added Vivo Security Repair - Added Samsung Knox Guard (KG) Status Change - NEW!!! MTK One Click - No need to select any model. - No need to select any DA/preloader. - Simply tick required options and execute. Supported SOCs for DAA/SLA Bypass: - MT6261 - MT6572 - MT6580 - MT6582 - MT6735 - MT6737 - MT6739 - MT6753 - MT6755 - MT6757 - MT6761 - MT6763 - MT6765 - MT6768 - MT6771 - MT6779 - MT6785 - MT6795 - MT6797 - MT6799 - MT6873 - MT8127 - MT8163 - MT8173 - MT8695 - MT6885 - MT6595 - MT8167 - MT6592 - MT6833 (Dimensity 700 5G) - MT6853 (Dimensity 720 5G) - MT8590 Added New SOCs for SLA/DAA Bypass: - MT6758 (Helio P30) - MT6781 (Helio G96) - MT6877 (Dimensity 900) - MT6893 (Dimensity 1200) Added Samsung Knox Guard Status Change - Change to Locked, Completed, Checking or Prenormal Updated MTK One Click functions - Improved Format/Erase FS - Improved FRP Reset Function - No more need to put in recovery manually on Safe Format/Vivo Reset Fixed Old SOC Issue - Fixed scatter file error message when working with older SOCs Improved Bypass Method - Make sure you complete libusb driver installation started with setup - If filter driver is not installed it will try to install it on bypass step - Now error message should be shown in case of any error Your Fast & Furious Source |
