UMTv2 / UMT Pro UMTv2 / UMT Pro UltimateHST v0.1 HiSilicon Service Tool Initial Version Released COM1.0 Flasher Supported Chipsets: - Kirin 655 - Kirin 658 - Kirin 659 - Kirin 950 - Kirin 955 - Kirin 960 - Kirin 970 Fastboot Info - It will let you read basic info in Fastboot Mode Flash Board Software - You can flash standard board firmware XML using this function - You can check/uncheck required partitions - Choose configuration from XML, Fastboot or Partial Erase - Option to protect critical data from write / erase Flash UPDATE.APP - You can flash APP firmware either via TP or in Upgrade Mode - Customizable flashing (not applicable in Upgrade Mode flashing) - You can flash multiple files one by one at the moment - Upgrade Mode Flashing Supported - Enable Downgrade/Protect Critical Data/Custom Flashing not applicable in Upgrade Mode Enable Downgrade - You can use while flashing using TP. - This option is checked by default. Protect Critical Data - This option will protect critical data from erase/write - This option in only applicable in COM1.0 / Fastboot Mode Backup OEMINFO - Backup OEMINFO data from COM1.0/Fastboot mode Restore OEMINFO - Restore OEMINFO data in COM1.0/Fastboot mode Backup Security - Backup Security data from COM1.0/Fastboot mode Restore Security - Restore Security data in COM1.0/Fastboot mode Reset FRP - Need to connect phone in COM1.0/Fastboot mode - It will not work if you enter Fastboot mode manually FwTP (Firmwwre TP) - This function will let you enter COM1.0 without disassemble phone - You need same version Firmware for your device - Strictly to be used only on Platform supported - Need to connect phone in Upgrade Mode to Enable FwTP - To exit COM1.0 Mode, you need to Disable FwTP EMMC Activation is Required for this Module https://scontent.flhe2-1.fna.fbcdn.n...25&oe=5FF6E0D2 |
