Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
09-08-2016, 15:43 | #1 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | [GUIDE] Huawei Y560-L01, TWRP + ROOT + Unlock Boot Loader Quote:
Downloads: TWRP recovery STOCK Recovery Booting to the recovery: * Turn the phone off. * Hold <Vol Up> + <Power> for about 5 seconds. (You have to hold them or it will just boot up normally..) Installation: * Install adb and fastboot on your PC. * Download the image. * Reboot your phone to the fastboot-mode. ("adb reboot bootloader" or from the recovery) * Type "fastboot erase cache" to format the cache partition. It can cause some problems, if it isn't erased. * Type "fastboot boot recovery.img" to test if it works. * Type "fastboot flash recovery recovery.img" to actually flash it. * Type "fastboot reboot" to exit the fastboot-mode. * when finish have TWRP installed and SU, only need of "Update Binary" by clicking in SU. * Phone Rootted and TWRP installed. Unlocking the bootloader: Note: Unlocking the bootloader WILL format your data! * Go to Settings -> Developer options and enable "OEM unlocking". * Reboot your phone to the fastboot-mode. ("adb reboot bootloader" or from the recovery) * Type "fastboot oem unlock". * If it doesn't work, try "fastboot oem unlock-go". IMPORTANT: For you security, do always a FULL BKP of all you Partition, like System, Boot, Datas itc... if want turn back in original state or anything goes wrong just "Restore BKP" USE ONLY THISBUTTON IN DOWN RIGHT CORNER BR allumts | |
The Following 4 Users Say Thank You to allumts For This Useful Post: |
02-06-2017, 14:20 | #2 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2681629 Status: Offline Thanks Meter: 0 | Hello, my phone is locked get this message FAILED (remote: unlock device to use this command) finished. total time: 0.408s to unlock the bootloader, I need the ID code but I can not see it because the phone is locked to google account there is a solution? thank you |
02-06-2017, 22:03 | #3 (permalink) | ||
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, Quote:
BR allumts | ||
01-14-2018, 12:05 | #4 (permalink) |
Junior Member Join Date: Jan 2018 Location: Florence
Member: 2799737 Status: Offline Thanks Meter: 0 | Hi, I have a few questions: 1: Do I have to put the "recoveryDOTimg" and "recovery_stockDOTimg" files in the adb tools folder? 2: When i try the "adb reboot bootloader" command my phone restart and the freeze on the logo Some advice? |
