Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei > Huawei Android based phones
Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help
Old 12-05-2019, 16:17   #16 (permalink)
Member: 1591394
Thanks Meter: 552
https://mega.nz/#!2MJSFCaI!VOYkncI2c...6ew5k6DyVE5FWY use this
The Following User Says Thank You to kikas112 For This Useful Post:
Old 12-05-2019, 16:34   #17 (permalink)
Member: 1591394
Thanks Meter: 552
and after board write this via sd dub-lx1
Old 12-05-2019, 16:34   #18 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 144
Originally Posted by kikas112 View Post
what exacly board software u used ? version ?
DUB-LX1_8.1.0_143_(185)_EDL_UNBRICK_DOWNGRADE_GSM-SOCIAL
DUB-LX1-BD 1.0.0.58 Board Software general 8.1.0 r1 EMUI8.2 05022NRB
these two files bro
Old 12-05-2019, 16:36   #19 (permalink)
Member: 1591394
Thanks Meter: 552
use that what i give u link and then use upgrade file from my link too all will be fine if before downgrade works good
Old 12-05-2019, 16:46   #20 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 144
Thanks bro im just downloading ur file and will let u know bro
Old 12-05-2019, 17:44   #21 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 144
bro ur link is only one file which board firmware there is no upgrade file in it
Old 12-05-2019, 17:50   #22 (permalink)
Member: 1591394
Thanks Meter: 552
u write board software ? all now good ? dub-lx1
this bys sd, vol- vol+ pwr
Old 12-05-2019, 18:02   #23 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 144
Ok thanks i will try .........
Old 12-05-2019, 18:03   #24 (permalink)
Member: 1591394
Thanks Meter: 552
first board software then check if all working good second update by sd
Old 12-05-2019, 18:08   #25 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 144
OK bro thank u so much i will check .........
Old 12-13-2019, 12:39   #26 (permalink)
zaskar's Avatar
Member: 60746
Thanks Meter: 56
what kind of software u used to write it to phone ?
The Following User Says Thank You to zaskar For This Useful Post:
Old 12-13-2019, 13:10   #27 (permalink)
Member: 1591394
Thanks Meter: 552
All what can write board software
Old 12-14-2019, 12:22   #28 (permalink)
Member: 2809111
Hi, I have DUB-LX1 C432, after unbrick there's no sound in earspeaker. I flashed fix files but it's not solved the problem.
Old 12-14-2019, 12:32   #29 (permalink)
Member: 2809111
Hi, I also have problem after downgrade, there's no sound in earspeaker. I flashed fix files but it's not solved the problem, upgrade also.
Old 12-14-2019, 13:29   #30 (permalink)
Member: 1591394
Thanks Meter: 552
read this thread again
Page generated in 0.20928 seconds with 8 queries
