Honor H30-U10 Imei NULL Honor H30-U10 Imei NULL How to fix imei write nv file write bur same IMEI NULL any best tool write for imei :confused: |
Flash with another firmware Chimera tool can help you |
problem solve thx for relpy |
how yuo solve problum i hane set in hand imei null |
Please read the the thread from beginning, you can get your expect solution. Send from my SM-G928F using Tapatalk |
Frist root and try with this apk Chamelephon 1.0 APK Download - Android Personalization Apps |
this solution doesn't work for me..any other solution ? |
Try This Method Quote:
USE Frist root and try with this apk Chamelephon 1.0 APK Download - Android Personalization Apps this solution is not work |
sheraziking110 bhai very very thanks ilove u ALLAH ap ka bla kary Ameen |
friends plz go in recvry mood wipe fctry nd cheh/ now reboot phone ur problam is slov tested by me |
New Working Solution is here read compleate article here Huawei Honor 3C H30-U10 IMEI Repair Solution 100% Tested Without Box Only Thanks Button ;) |
Sometimes when the we read the phone and the imei is there but in the screen *#06# appears NULL, we need to format all the partitions (Except bootloader) and re-flash de phone again. The steps are: Write memory with spflashtools v3 to unlock the bootloader with the secro scatter loaded. Flash secro. Then format all partitions except bootloader. (Very important) Flash de firmware (In my case B108 worked). Now you can write the imei via adb (You will need root first, you can use KingoRoot) or you can flash with tools like Nck via SpMeta connecting the phone powered off. The imei should appear now. |
solved my customer phone. tnx alot |
