Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
10-28-2015, 23:33 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Huawei NexUs 6p [Firmware] [Root] [Custom Recovery] Huawei NexUs 6p All in One Thread Fastboot+Adb Driver Factory images for Nexus 6P [Angler] 6.0.0 (MDA89D) 6.0.0 (MDB08K) Flashing Procedure: * Goto Settings /About Phone/ Tap on Build numbers 7 to 9 times until Developer mode is enabled. * Goto Developer Option enable OEM Unlocking & Usb Debugging Turn off Your Device Hold vol Dwn + Pwr Button to Get into fastboot Mode nd run Below given command to unlock your Bootloader. fastboot oem unlock [This will full erase your Data's] * Extract the firmware zip * After Extract yu vil get a single file * Change tat files extension to .tar or .rar extract it * Again extract it after change the Extension yu vil get files below given in the picture. * Connect yur mob in fastboot mode * Run the flash-all.bat Root & Custom Recovery Installation Download Boot File Download Twrp Recovery * Bootloader Must Be unlocked (Guide available above) * Copy boot.img & Recovery.img to fastboot adb folder. * Connect Your Device in Fastboot Mode * Run Below Given Commands To flash the images. fastboot flash boot boot.img fastboot flash recovery recoveryname.img fastboot reboot Supersu 2.52.zip Copy Supersu 2.52.zip to sdcard and flash via twrp or sideload to flash it. ____________________________________________ |
The Following 6 Users Say Thank You to jamesjerss For This Useful Post: |
08-25-2016, 03:24 | #7 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Republica Dominicana Age: 40
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | that's my same question, it is possible to downgrade from 6.0 to 6.0.1 to remove frp? in my case I need firmware 6.0.0 MTC20F Last edited by alexis_01; 08-25-2016 at 03:33. |
02-18-2017, 16:02 | #9 (permalink) | |
Insane Poster Join Date: Sep 2016 Location: Pakistan
Member: 2619139 Status: Offline Thanks Meter: 20 | Quote:
04-30-2017, 14:35 | #11 (permalink) | ||
Freak Poster Join Date: Sep 2012 Location: Loading! Age: 34
Member: 1813502 Status: Offline Sonork: 100.1623430 Thanks Meter: 182 | @jamesjers Can u please guide me that when device is stuck on boot logo and not completely boot then how is possible to enable oem unlock option? Because with bootloader lock flashing failed Quote:
I tried to unlock bootolader with following commands Quote:
And without bootloader unlock flashing failed. So is there any way to flash the device? | ||
The Following User Says Thank You to M.S.khan For This Useful Post: |
