Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
02-26-2022, 16:47 | #1 (permalink) |
Freak Poster Join Date: Jan 2015 Location: GSM Net Age: 46
Member: 2334036 Status: Offline Thanks Meter: 131 | Huawei P30 Pro After Battery Replacement Reboot Loopup Problem Thanks in advance |
02-26-2022, 17:56 | #2 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 252 | tranfer the batery board of the original batery to your new batery..hope it helps |
The Following User Says Thank You to simpleprince49 For This Useful Post: |
02-28-2022, 16:16 | #4 (permalink) |
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 252 | check this he opened the batery and fix the board but yours...you need to tranfer it to the new batery..remove its batery board there and put the original batery board to it..i hope i explained this well Last edited by ...:::::NP™:::::...; 09-26-2022 at 22:10. |
02-28-2022, 16:52 | #5 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | Quote:
OR if it is new OEM battery, never paired with other board, should work w/o any problem | |
03-10-2022, 05:39 | #7 (permalink) |
Member: 2334036 Status: Offline Thanks Meter: 131 | Huawei P30 pro and all P40 models. 1. Switch on the cell phone with the old original battery and leave it connected to the charging cable. 2. Change the new battery in the switched on and connected charging cable. 3. wait until the mobile phone has charged to 100%. NOTICE! Be sure to wait until 100% has been reached and then leave it on the charging cable for 5 minutes longer to be on the safe side. The battery can sometimes remain at a % level when charging, DO NOT unplug before 100% , a detected error from the battery is corrected directly by the mobile phone and the battery is recognized. PS: keep the old battery, if at some point the battery has to be put back in the phone, then you have to do it again. That's why the battery isn't thrown away. |
03-12-2022, 15:47 | #9 (permalink) |
Member: 691388 Status: Offline Thanks Meter: 371 | hot swap methode only for home users with assumed risk. Professionals shoukd go for reprograming new SN Trimis de pe al meu SM-G998B folosind Tapatalk |
The Following User Says Thank You to maremestera For This Useful Post: |
09-26-2022, 21:54 | #12 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,772 | Quote:
(i've had such case on p30pro) And, yes - if you have active tools, reprogram, if not - battery swapping trick works, i've personally test. Zero problems after such swap. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
09-26-2022, 22:24 | #13 (permalink) |
Moderator Join Date: Nov 2009 Location: Italia Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,105 | Hi, Dear forum members I have seen the video about battery replacement of normal huawei android phone but my view is that normal huawei phone battery and your smart chip based phone battery are mostly different. If you have an old battery sticker with a serial key, set the serial key with professional tools and hopefully your Rebooting problem will be completely solved.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
09-27-2022, 19:15 | #14 (permalink) | |
at least, after US ban on android, nobody is buying that crap anymore p.s. chinese trash phones with "battery protection", it's like their chinese neighbours cant make the same battery with same chip ? lol. at least i'm happy not to see that trash brand anymore, like sony disappeared in this region b.r. Alex
02-03-2023, 11:48 | #15 (permalink) | |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,636 | Quote:
